Need spark plug help!
Old Jan 1, 2013 | 10:00 PM
MDUB87's Avatar
Default Need spark plug help!
Hey guys, I recently picked up a 99 trans am, and the previous owner had a dry 75 shot installed on it. my question is as with most new cars I buy I want to do a full tune up, plugs, wires, etc. I have a set of TR55IX plugs for LS1 laying around the shop, will they be too hot for the 75 shot? I'm new to the nitrous scene, and in all honesty when I do run it, it'll be a rare occurrence, at least for awhile until I get accustomed to nitrous.
Old Jan 1, 2013 | 10:07 PM
Blackpanther99's Avatar
When it comes to Nitrous I have always preffered NGKs, but then again im not a nitrous guru lol
Old Jan 1, 2013 | 10:08 PM
MDUB87's Avatar
my plugs are NGK TR55IX
Old Jan 1, 2013 | 10:19 PM
MDUB87's Avatar
I'm just curious if I need to worry about running something like ngk br7ef when i'm not going to spray too often, and it being a 75 shot.
Old Jan 1, 2013 | 11:59 PM
boostit5.3's Avatar
i've sprayed a 100 wet shot in my 5.3 with those plugs and had no problems. however i did just go one step colder because i plan on upping the shot to a 150.
Old Jan 2, 2013 | 01:30 AM
MDUB87's Avatar
Thanks for input, what do you think I should gap the plugs to? and yes I know how to safely gap an Iridium plug
Old Jan 2, 2013 | 07:34 AM
Codytaylor90's Avatar
Ngk all day. I haven't ran must nitrous but my understanding it that you want to go colder of course and I believe by two sizes
Old Jan 2, 2013 | 01:58 PM
boostit5.3's Avatar
i gapped mine to 035
Old Jan 2, 2013 | 03:50 PM
Neal@NitrousOutlet's Avatar
i wouldn't recommend it. If you run just a hair to much timing the tip on that plug will be melted off. Those are projected tip plugs and can burn the straps quickly. I would change them out to non projected tip plugs if you are looking to spray. I would rather you be safe than sorry.
Old Jan 2, 2013 | 09:44 PM
MDUB87's Avatar
Thanks for the info Neal! What plugs would you recommend then? will running the colder plug hurt my n/a performance enough to even notice or care?
Old Jan 3, 2013 | 10:19 AM
Some people notice a little difference with the BR7's but on the flip side some people don't notice a difference at all. I can give you this much info. If you NA tune on the 7 plug you shouldn't see any performance or running problems.
If i were you, i would buy a set of NGK BR7EF (3346) and put them in your car. Gapped at .035. Drive around and see if you notice any difference. The safety alone on nitrous will be more than enough for me to run them. Plus they are a $1.99 - $2.25 ea. Its not much money to have some piece of mind.
Iridium tips are so fine they can be nipped with increased heat from the nitrous as well and cause running problems.
Old Jan 3, 2013 | 08:36 PM
MDUB87's Avatar
I ordered a set, I really appreciate the help, input everyone! Thanks!
Old Jan 5, 2013 | 03:30 PM
dekan513's Avatar
br7ef all day
