Need TNT F1 Wiring Diagram ASAP!!!
Senior Member
Heres one with a window switch, Im sure you can figure it out if you dont have the window switch.
<img src="http://www.imagestation.com/picture/sraid29/p8605c2fe855e3ba95f3dad6cb2ef266b/fd5c4a39.jpg" alt=" - " />
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
1 Post
Do the ground wires coming from the 2 solenoids tie into the fuel safety switch as well as the #85 position on the relay? Does this in turn go to a ground on the vehicle, or does the ground on the MSD provide the ground?
Tim
Tim
Senior Member
The solenoids go to a chassis ground. Pin 85 is actually the ground for the relay. Thats how the window switch works. It controlls the grounding. If using a FPSS and a window switch, you just put the FPSS in the yellow wire. One yellow from window switch going to FPSS and then the other side of the FPSS to pin 85. If not using a window switch, you put both ground wires on the FPSS and the other side to a chassis ground and just ground pin 85. That way the FPSS interupts grounding of the solenoids if something is wrong. Check with TNT to make sure Im right though.
BTW~ Its no problem Todd <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ October 19, 2002, 10:32 PM: Message edited by: Country Boy ]</small>
