NO2 question
Old Mar 20, 2018 | 03:30 PM
curtisad's Avatar
Default NO2 question
I am currently running a dry 100 shot and I have been waiting until I get to third gear before I switch it on manually.
Is it safe to just go full throttle and have it spraying between gear shifts? I have the original "timing tuner" but am not really sure how to program it. I know there are more modern user friendly controllers but, I don't eat nickels and $hit quarters.
Any advice would be greatly appreciated.
Old Mar 20, 2018 | 03:38 PM
HCI2000SS's Avatar
With only a 100 shot why are you waiting until 3rd to spray? I'm just curious
Old Mar 20, 2018 | 03:43 PM
curtisad's Avatar
Because I am concerned for going to lean between shifts.
Old Mar 20, 2018 | 03:55 PM
HCI2000SS's Avatar
On a 100 shot you don't need to waite till 3rd before spraying. It can take far more strees than that. It looks like you have a built tranny as well?
Old Mar 20, 2018 | 03:58 PM
curtisad's Avatar
Yes I do.
Old Mar 20, 2018 | 04:00 PM
HCI2000SS's Avatar
Honestly with a built tranny and only a 100 shot you can spray through the shifts no problem and be fine
Old Mar 20, 2018 | 09:50 PM
baronsmith98's Avatar
Spray through the shifts. If transmission breaks then fix it
Old Mar 21, 2018 | 05:00 AM
98redorangeta's Avatar
http://www.fullthrottletech.com/atta...ttachmentid=82
Here is the instructions on the timing tuner box it’s a window switch too so you can set it to shut off before the shift.
Old Mar 21, 2018 | 10:33 AM
allblackedout5's Avatar
I sprayed 200 through shifts...built 4l60e no issues. Do it....
Old Mar 21, 2018 | 05:38 PM
ragtopz28's Avatar
^^x2^^
Old Mar 21, 2018 | 10:18 PM
tug686spd's Avatar
I agree with these guys on spraying through. Depending on you tune as far as shift rpm vs mph vs rev limiter it might need adjusted. The extra power will definitely let the converter flash a little higher off the line if the tires will hold it, it might make the converter a little less efficient up top to. If it is less efficient up top it will meet the rpm requirement for the shift at less mph than before which will let it climb higher in Rpm's before it shifts while waiting for mph to hit requirements. If your rev limit is close to your shift points it could bounce of it waiting to ****. Not saying it will happen but it's possible and something to watch for.
Old Mar 22, 2018 | 08:49 AM
Bowtiedford's Avatar
I thought you where talking about a manual trans lol, my 4l60e I spray 300 off the start all the way through and don't give it any thought but that's me
