Dry vs. Wet Jet Sizes for HP levels
Cuz I AM a BADMOFO
I can't seem to get a straight answer on this one. I have a dry system on my 5.3 Silverado, and I need to know the jet size needed for a 75 shot and for a 100 shot. I've had several people tell me that a wet system needs a smaller jet to attain the same power level compared to a dry system. One guy (on LS1Tech) just told me that a 75 shot wet needs a 47 jet, and a 75 shot dry needs a 96 jet
. I'm confused on how wet or dry would make any difference. I even linked the jet chart found above in the sticky to this guy in a PM and he said that those jets sizes/power levels were for a wet system?? Also, wouldn't a dry shot need less of a jet (if there were any variance) since I would expect it to be a tad leaner if anything then a wet system???
Somebody with some experience help me out, as I'm off to the track this Sunday and would like to know what I got before I get there.
Thanks.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Just use the jet chart in the sticky (colonels nitrous files)
http://home.ican.net/~jsetter/nitrous.html
There are alot of variables that will decide what you see at the rear wheel. Bottle pressure A/F etc. Youre just spraying a small shot dont sweat it. Use the chart not what somebody (you dont even know) tells you
Cuz I AM a BADMOFO
I know that the "variables" will play into it, and not every car will pick up the same, but there has to be a "set standard" as far as this goes. I know this subject has been beaten to death, but there still doesn't seem to be a straight answer. I've read the sticky, I've done searches and ready every post on the subject. Some say that the .47 jet in a duel nozzle set up like the NOS will need to be doubled in a single nozzle set up to duplicate the same power, but I just don't know. I just don't want it to be TOO small of a shot. Hell if the above is true, and I use a .47 jet in a single nozzle, I'll be lucky to get another 50hp out of it. Thanks for your time.
Some say that the .47 jet in a duel nozzle set up like the NOS will need to be doubled in a single nozzle set up to duplicate the same power.
I disagree with that statement and so does the chart.
The chart says
100 shot=.047 single jet or .032 double
75 shot=.042 single jet or .028 double
Take the 100 shot .047 is not twice the .032 from the double.
The actual way to compare flow rates of different orifices is a method of squaring the nozzle size. For instance .047x.047=.002209 this is the single nozzle
.032x.032=.001024 per nozzle. there are 2 nozzles so you multiply by 2 =.002048
Thats how you would calculate it. there is a small difference between the 2 but this chart isnt designed to navigate a man to the moon its just a guide. Again read the chart it shows the shot for single N2O setups and for dual N2O
The chart says
Cuz I AM a BADMOFO
The chart says
The chart says
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
The chart says
The chart says
The radius of the inside diameter squared x Pi = cross sectional area of a round hole
And it’s why (2) .032 orfice flow about the same volume as (1) .047 as stated in the chart
The following 2 users liked this post by gametech:
G Atsma (11-06-2021), Z28SteveA4 (11-07-2021)
The following users liked this post:
G Atsma (12-31-2021)
