i need instructions for a dynotune remote opener to an NX switch panel
i bought the kit used and their are no instructions for the remote opener and i can't figure out the instructions for the nx opener
someone please help
someone please help
Check NX's site and go to instructions, then go to the switch panal instructions. It's fairly universal and should work, if it doesn't, then like said, it would only be two wires that need to be reversed.
Closed ex-Sponsor Account
http://www.nitrousexpress.com/Instructions/opener.pdf is our instructions the wiring should be the same.
Ricky
Ricky
The switch you need should have 6 terminals on the back side. As long as the switch is a double pole double throw, monentary switch you should be able to wire it the same. Right upper left lower go together(hots), left upper right lower to together(grounds), and the middle t\2 terminals go to the opener motor. switch up or down to see what happens.
Ricky
Ricky
