car bogging right when i spray
i launch and right when i hit 3 grand i go to spray and the car bogs and falls on its face for about a second or two, then it flys like a bat out of hell. i have a purge and i purged it every time i raced and the bottle pressure was at 950 so i dont know what the problem was.
when i was on the freeway i did a couple pulls, the first time i sprayed it bogged and then flew but i slowed down and did it again and it was fine.
the car feels like its getting all fuel and no n2o for a second on the initial spray.
any ideas because i have no idea
Bog from overly rich or overly lean. One or the other, both will cause a bog, but the tale will be in the reported AFR.
i scaned one run with my aeroforce gauge and i accidently didnt have it on the o2 readings. it was on knock and something else.
i dont have a fpss yet, thats why i watch my o2s when i start pulling through the gear to see if it starts to lean out
EDIT: Are you using a NOS bottle or the HSW one? What do they weight?
Matt
i dont have a window switch yet, im waiting for my buddy to get one off my friend.
i have a microswitch and an arming switch.
what i do is launch the car with the arming switch off and right when i get to about 3250-3500 rpms (as long as i am hooked and going) i turn on the arming switch, and the car is already floored so it sprays, it bogs the car for a second or two, then it feels like God comes down and kicks the car because the bitch flies like hell and is fine after that through all of the gears
) try it with the arming switch on, then go WOT at 3k. Also check for a flakey connection somewhere. If you can log your O2s that would be even better. I assume stock fuel pump?Matt
but i cant see it being the connection because when i left the track, i went to spray it on the freeway, it bogged the first time, then i slowed down and did it the same exact way and it didnt bog.
i know hitting the arming switch isnt the best way of doing it but i figured it would be ok sice i dont have a window switch yet
can you shed some light on that so i know what im looking for. because im pretty lost on what it could be.
Could be stock fuel pump.regulator playing catch up and just making a microsecond of leanness, the NXL kit did this when it first hit the market, nothing to panic about.
BTW, what plugs and gap?
Matt
