602rwhp/780rwtq SAE 10.05@135...LT1!
It has been an all out thrash weekend. All day yesterday on the dyno(dyno kept crashing) then a fast trip 100+ miles and a ferry ride to the track. Disappointing first night out ending with only a match of my best time. THis does not even include ripping the intake off after I drove it home from work Thursday!
Then today getting back up and going to the track and having a pretty good day oil leak and all![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
We have vid of dyno's and runs with Mod's for wittness's![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Dynos were brutal tearing up a set of M/T ET Streets on the rollers. It just kept shreading them when the juice came on. first pull she made 780RWTQ at 4,000 and 588RWHP. We kept upping the RPM we hit the juice but it never really did help. Last pull showed 660RWTQ and 601.8 RWHP.
Dave's jetting was down to the HP on the money!
The sickness of it all? It made over 590RWHP from 5,000 to 7,000!
Here is what she look's like going down the track.
Excuses for no Nine's are...Spun coming out of the hole...hit 7,200 limiter on 1-2 shift and started going lean on the big end. We would have made more runn's but the oil fitting on the back of the block fractured(during a intake swap thursday night) and started spraying oil every where.
I would like to give a HUGE tanks out to N2O Dave and his crew(Especialy Chris) for making this happen this week! With out there help this week and on the dyno friday this could not have happened!
Also the Local crew who helped in more ways then we can explain!
Jimbob,Mark,Ryan,EJ, My Wife and many more!
Thanks everyone!
Thanks everyone!
Nice work Ellis. That things a beast for sure, and can't really be appricated without seeing it go down the track in person. Your hard work has paid off, and you now have the fastest LT1 in the NorthWest, with certainly a 9.xx coming.
By the way, I did see the brutalized tires.
Robert
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Robert
OWN3D BY MY PROF!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![](http://img169.imageshack.us/img169/4262/tanksdaveandchrisxl8.png)
Those are some really good results. You should definetly hit 9s when you fix all the problems you listed. Wanna give out some details on the setup or is it
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
MODS
ENGINE:
SSEFI LT1
Splayed 4 Bolt
Eagle 3D 6in Rods
Eagle 4340 Non-Twist Crank Shaft
J&E Flat Top Pistons(12.0:1)
CSI Water pump
SSEFI Cold Air Intake
1LE bellows
LPE 58mm Throttle Body
LE-X Ported LT1 heads 2.055 Int 1.57 Ext
SSEFI Custom 240/247 CamShaft
Double Roller Timing Chain
Crower Chrome Moly Push Rods
Hooker Long Tube headers
TwoFast4LV Custom Y-Pipe
Dynomax 4 inch In/Out Muffler behind Y-pipe
DHM Electric Cutout
SLP Duel Duel Cat Back
DRIVE TRAIN:
Yank Thruster Pro 3800 stall
NW Differential Built 3.73, 33 spline 12-bolt
Eaton 33 spline HD 1000Lbs bias
T/A Rear end Girdle
RaceTronix Fuel kit Kit
MSD 6T ignition
SLP Fan Switch
SSEFI Built, Calibrated and Tuned, 4L65E
Speed Secrets tuned motor with Tune Cat
SUSPENSION:
'98+ brakes
Bogart/Mickey Thompson ET Street Wheels for drag strip
Polyurethane bushings
26mm rear bar
BMR TQ Arm
Adjustable LCA locators.
Lakewood LCAs
Lakewood Pan Hard
TwoFast4Lv SFCs
HAL 12-way adjustable shocks
HAL drag springs
EXTERIOR:
SLP SS spoiler
2001 SS 17" rims
PIAA Low beams and Hyperwhite High beams
PIAA Fog lights
Six light conversion (four head lights and two fog lights all at once)
Clear corner lenses
Rebadged with Bowties
Zaino!
INTERIOR:
Color matched Gauge panel
Graphite Cloth
Bose Five speaker CD
SAFETY/MISC:
Morrison 8 point Roll Bar
G-Force Five point harness
Custom Built DS safety loop
C-Clip eliminators
RCI Tansmission Blanket
Ford Starter Soleniod
SFI Flex plate
SFI Harmonic Damper
DYNO:
412 RWHP / 422 lb/ft torque (S.A.E. corrected)
602 RWHP / 780 lb/ft torque (S.A.E. corrected)
BEST 1/4 TIME:
11.47 @ 118 mph with a 1.59 60' (NA)
10.05 @ 135 mph with a 1.49 60' (N2O)
ENGINE:
SSEFI LT1
Splayed 4 Bolt
Eagle 3D 6in Rods
CSI Water pump
1LE bellows
DHM Electric Cutout
DRIVE TRAIN:
T/A Rear end Girdle
MSD 6T ignition
SLP Fan Switch
SUSPENSION:
'98+ brakes
26mm rear bar
BMR TQ Arm
Lakewood LCAs
Lakewood Pan Hard
TwoFast4Lv SFCs
HAL drag springs
EXTERIOR:
SLP SS spoiler
2001 SS 17" rims
PIAA Fog lights
Clear corner lenses
Zaino!
INTERIOR:
Graphite Cloth
SAFETY/MISC:
C-Clip eliminators
SFI Flex plate
SFI Harmonic Damper
DYNO:
BEST 1/4 TIME:
Originally Posted by Beaflag VonRathburg
Was bored and thought everyone could get a laugh out of this.
OWN3D BY MY PROF!
Originally Posted by Ima get mines
Did you lose a signature bet? ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
http://www.seatstaysup.com/forums/showthread.php?t=2831
Back on topic, so TwoFast4Lv you're hitting it with something around a 200 shot?
So your cars pretty sneaky huh. Ported stock castings and the money maker
. Oh it's just got a cam. ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I offered a guy $50 if he could find my Noid's the other night...and I didn't have to pay
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Dave, There will be many more after this
