nitrous motor help!!!
Cody Roberts
http://www.race-cars.net/calculators...alculator.html
You should also post some more info like do you want a stroker setup or not or do you just want a plain 350 CI motor. Once you have all that you can go from there.
383, Callies crank, eagle rods and JE pistons, billet caps, o-ringed block.
I parting out my car right now too. If you are interested in any of it please PM me.
The most important thing you can do to a small block is ditch the factory 4 bolt mains and get some nice billet caps. It makes a huge difference.
Trust me, it sucks when you blow-out all the mains and the expensive cranks pushes through the oil pan. I learned that lesson.
What do you run for coating? Just curious, since I hear good things about that, but never personally tried it.
As said above, don't be cheap on the crank & rods either.
