will a 100 shot be O.k
Old Nov 9, 2006 | 08:15 PM
chris77's Avatar
Default will a 100 shot be O.k
my car makes 385rwhp and i was spraying a 75 dry but i just upgraded to a 255 walbro pump and the 30# injectors so can i now spray a 100 without a problem
Old Nov 9, 2006 | 08:52 PM
Todd157k's Avatar
Shoot this question over to Robert56. He's the dry shot expert and can take a good look at all your other mods.
Old Nov 9, 2006 | 09:23 PM
HD1911's Avatar
hit up the Nitrous Forum...u will find the answers u are lookin for. In short, yes u can easily spray 100 dry with ur setup. Y not spray a bigger shot, i am throwin a 250 shot at my stocker and it loves it
Old Nov 10, 2006 | 12:51 PM
Robert56's Avatar
Well here's the easiest way to tell if you ma get into trouble.
(Projected flywheel HP x .5) / 6.4 = min inj to meet 80% DC rule
So we first need to turn your projected hp into BHP. We just subtract 15% from your anticipated 385rwhp + 100rwhp shot = 485rwhp.
485 - 15% = 412.25bhp
412 x .5 = 206
206 / 6.4 = 32.18 injector to meet the 80% duty cycle rule. So, your 30's will be fine at these hp levels. Don't worry about going over 80% on a short 1/4 run, won't cause any issues, we just don't want static (100%).
I would still log a/f and kr on intial runs.
Robert
Old Nov 10, 2006 | 01:10 PM
chris77's Avatar
i just logged the car on a 75 shot and my duty cycle at one point was 87% so i am kind of worried i guess i need to get back to the dyno to read my A/F. i am still new to all this tunning and stuff and just want to be safe. i did spray once or twice before a 125 dry with the stock injrctors with no problem so i am gonna go ahead and do a 100 today and some more logging i will post up later the results.
Old Nov 10, 2006 | 01:18 PM
Robert56's Avatar
This is my personal opinion. 87% duty cycle is nothing to be worried about, your fine and still have some room. Now if you show a lean issue you now know it is not due to running out of injector, so then look at nozzle placement/style/type and or fuel system ie: pump. If you have the ability to log or see fuel pressure, if it starts dropping off at your highest demand then pump replacement may be an idea, if it is lean through out run them nozzle(s) tuning may be needed, or tune PE in pcm. Good luck and keep us posted.
Robert
Old Nov 10, 2006 | 01:31 PM
chris77's Avatar
well i just installed the walbro 255 pump with the new injectors so i should be good. i do have HPtuners that i recently got but realy dont know much about it so far all i have done is some data logging and tune for the injectors. i am about to go wash the car, put my M/T's on and put in the 100 shot pills. tonight i have a race against an 04 cobra thats making 495 rwhp so i'm hoping everything go's well. this cobra freakin moves but i think i have a good shot
Old Nov 10, 2006 | 01:50 PM
Robert56's Avatar
You can use your narrow band readings from your HP tuner to get an idea of rich or lean. Your WOT 02's in the range of .880/.890 (12.8/12.9 a/f) are ideal for n/a. Higher numbers mean richer (which on the spray you want) and lower numbers mean leaner.
Robert
Old Nov 10, 2006 | 03:12 PM
chris77's Avatar
Robert
thanks for the info i will check it out tonight.
Old Nov 28, 2006 | 09:43 PM
marthastewart's Avatar
so how did you ever do against the cobra?
