NPB but service engine light on??
Old Dec 12, 2006 | 07:54 PM
Christian8A's Avatar
Default NPB but service engine light on??
11.2 on a 150 shot was the last pass at the track, and drove the car back home no problems at all , the car was normal. Started the car next day and the service light came on. The car still have stock tune, only TR6 plugs. The last pass I put 110 octane fuel on it and that was all that day.
What could it be, just guessing before I take it to scan it? what usually happens, spark plug burnt, or fluids?
Old Dec 12, 2006 | 07:58 PM
Brett H's Avatar
Was the 110 leaded fuel?
Your best bet is to just get the code read and go from there.
Old Dec 12, 2006 | 08:38 PM
wow, I didnt put attention to it, but I dont know is the one they have at the track .. ya to scan it but is a little far from where I live, Ill change the plugs first, what can I do next if the light wont go off?
Old Dec 12, 2006 | 08:40 PM
MeentSS02's Avatar
Kleeborp the Moderator™
My guess...you ran leaded fuel and killed the O2 sensors. But that's only a guess. I'd start there first.
Old Dec 12, 2006 | 09:06 PM
BadAssFast's Avatar
I'd slow down there a bit...SCAN first!! I'll bet P1137 or P1035 something in the 02 sensors if leaded fuel was used. Right or wrong, I mix 110 Renegade with 93 Sunoco. I get those codes EVERY time I race and mix this way. I kept my Hypertech just to clear codes and by the second full tank of 93 Sunoco, i'm gold again. Get your computer read after another tank of straight unleaded. Clear it and see if you get the code again.
Old Dec 13, 2006 | 12:31 AM
00formLs1's Avatar
thats what i think if it was leaded gas.
Old Dec 13, 2006 | 05:48 PM
mrr23's Avatar
well, until you pull the codes, my guess will be a plug or two melted the tips off. is it running rough now?
Old Dec 13, 2006 | 11:28 PM
Brett H's Avatar
He stated that he drove it home from the track and it was fine so I would suspect the plugs are fine.
Just pull the code and post it up, its the easiest way to diagnose your problem.
Old Dec 14, 2006 | 01:06 PM
Ok yea the code is P1153 and P1153 Fuel Air Metering, I put already 93 octane on and Ill wait 1 or 2 days and then Ill pull that code out, shouldnt come again right? unless one of the sensors is gone?
Old Dec 14, 2006 | 01:08 PM
00formLs1's Avatar
i think you may need to go thru a tank or so.
Old Dec 14, 2006 | 05:27 PM
I think so. So what just pull the code out after that tank or just unplug the battery for 30 mins
Old Dec 14, 2006 | 11:06 PM
01'WS6's Avatar
More than likely it was leaded if it was 110 from the track. Run through a tank with a few good WOT runs to "clean" the o2's and then just un-hook your battery for a few mins. 30 mins is overkill but it wont ever hurt anything if u have nothing better to do.
Old Dec 15, 2006 | 11:18 AM
Brett H's Avatar
Does unhooking the battery reset the pcm? I thought you had to pull the ign and batt. fuses under the hood with the key forward to access. for the pcm to reset?
Old Dec 15, 2006 | 11:35 AM
well last time a plug cable was not plugged right, the service light came on, and I unpluged the battery and the light went off
Old Dec 24, 2006 | 09:16 PM
nate-roth's Avatar
All the unleaded race gas I've seen here is 100 octane, just so you know. You can also clean your o2's w/ some aerosal non-chlorinated brake parts cleaner. Will clean residue of the sensors and evaporate away.
