What's the result of a 300 shot w/ TR6's & 26 degrees timing? What about a 200 shot?
just curious what would happen. Is a TR6 really a "glow" plug with that kind of spray? I understand risk..... I am asking about cause & effect.....
I am aware a TR8 is safer.... but what happens with a TR6?
A broken ringland here. I added 4 degrees of timing instead of pulling said timing and well the pics show what 26* of timing can do with race gas and 10.5:1 a/f and tr6's. More info on this in the thread below for some insight, as we don't want this to happen to someone else.
Blowing the LS6 on a 285rwhp shot
Robert
Robert
8 second mod
robert, for what its worth, the plugs didnt do that. the plugs being a hotter plug will melt sooner yes, but at that point letting off the gas would prevent damage. a hotter plug with the right monitering and driver is accually good. you can feel the car nose over, and lift. if you can get a hot plug to last, a cold one is even better.
everyone says i need to run 8's on motor ect ect, i run 6's with no issues and over 30* of timming.
Well Dave misunderstood, I was running 22* of timing and meant to pull an additional 4*, but made a mistake in tune and added 4*. If you had read on it was stated. How in the hell Noyzee is running 30* is beyond me. it's not only a safety thing, but nitrous will in fact work better and more efficient with less timing. On my 408 and 300/350 I will see 16*/14* of timing.
Here's why my weak piston failed: pre-ignition led to detonation, which this quote explains very nicely:
So if ya want big cylinder pressures at the wrong time then run lots of timing on the spray.
Robert
Edit: My above pics and scenario is with Hypercraptic stock pistons, of course we can away with more when running forged nitrous pistons etc.
Nitrous increases the speed of the flame front, so you're bringing the advance back to properly time the pressure spike to the retreating piston
Robert
Well Dave misunderstood, I was running 22* of timing and meant to pull an additional 4*, but made a mistake in tune and added 4*. If you had read on it was stated. How in the hell Noyzee is running 30* is behond me. it's not only a safety thing, but nitrous will in fact work better and more effiant with less timing. On my 408 and 300/350 I will see 16*/14* of timing.
Here's why my weak piston failed: pre ignition led to detonation, which this quote explains very nicely:
Robert
Robert
did you get my PM?
I doubt it.... either it is a valve issue.... or it is a ringland. The bearings should be okay. I checked all the rocker arms... they looked alright. It does have a loud pop on startup...... hopefully it is not the bottom end... but I doubt it wont be.
I have 8's in it now... a little too late huh? The standalone has plenty of gas in it.
What timing were you running? I contend that maybe my tr6's would have been allright except for the timing turning them into blow torches.
Robert
I run 10s and still take them out on an occasion. It is all in the tune. You can run 6s but you better not have any timing at all. I run my motor on a total of 9 degrees while on the bottle. I also run very low bottle pressure 800psi to keep my tune in shape for the whole run and to not beat up on the temps in the combustion chamber. My EGTs are around 1300.
Mike what compression are your running. that plays a role in timing also. Where I could get away with 14/16 degrees with a 300shot and 11.25:1 compression, Guesswho could not with his 12.5:1 compression. So timing is relative to size shot and compression amongst other parameters.
Robert
Robert
