Wiring Guru's Please Enter!!!!
Hey guys,
Need some help here...Im getting the nos launcher and tryin to figure out how to wire it up for two stages and use one of the inputs for tps...Im not really good at wiring all this stuff but I do understand once I see it. I think the instructions are just kind of confusing me...I would like to use a switch for each stage to turn it on and off for each stage so if I want to run stage one i can or just stage two or both...where would I stick the switches for stage one and two? Could someone please lay out a diagram for me??
http://www.holley.com/data/Products/.../199R10466.pdf
That is the link for the instruction manual...
Thanks
Thanks
It seemed to me that if I use the yellow/orange wires and program it that I would not be able to use the tps setting...I want it to where I can contorl it from a switch panel...on the panel I will have a switch for stage one and another switch for stage two.....
Although I don't know the program, according to the instructions, you could control those lines by the tps also. You'll have to read more into the program. If nothing else, you can use a couple switches and relays. This would "shut off" one or the other, or both. Relays are available at radio shack. I bought a bunch of 20 with connectors off ebay for $10.
