is this normal??
Old Dec 8, 2007 | 08:01 PM
allforspeed's Avatar
Default is this normal??
so...... finally took my car out and sprayed the baby 50 shot to make sure everything is working ok before i take it to the dyno
awesome!!!!! was really surprised how much of a difference just a 50 shot makes, especially in second gear!
one weird thing happened though:
when i was spraying in fourth gear from 3500pmr to 5000rpm, and pretty much every time i was spraying, the speedo jumps around abit, maybe 5-10mph up and down while i'm spraying, and its not wheel spin (i wish!), i'm assuming this is just the solenoids sucking electricity or something?? could this be the fuel pressure safety switch or the bottle heater kicking on??
new to this nitrous ls1 game and want to make sure i'm not hurting anything, little worried
my setup:
car only has lid, granatelli MAF, 3.73 gears, and flowmaster muffler
nitrous express wet kit
NGK Tr6 plugs
MSD window switch set at 3K-5500K
bottle heater
50 shot pills for now
spray nozzle plumbed into the bellows
Old Dec 8, 2007 | 08:13 PM
also: if it was knocking/pinging on the nitrous you think i would hear it? or would i never know until i blew a headgasket or pulled the plugs?
Old Dec 8, 2007 | 08:22 PM
sleeperstyle's Avatar
the speedo thing is strange...
fuel pump
dyno tune
= no worries about pinging or anything else.
and stop using the "octane booster". if you really want octane use toulene/xylene mix (search it on yahoo or whatever) or unleaded racegas ($$). you don't need it though.
Old Dec 8, 2007 | 11:29 PM
thanks, i guess if that doesn't happen when you all spray then i should stop and wait till i have it on the dyno....
plan on doing the fuel pump and dyno tune this month but figured 50 shot was small enough to be safe and wanted to make sure my set up was working proper before driving super far to go get dyno tuned
Old Dec 8, 2007 | 11:31 PM
when a ls1 detonates on spray can you even hear it?? or does it just blow up and you never hear a thing until it goes?
Old Dec 9, 2007 | 12:22 AM
also two other questions:
do you all think my granatelli mass air flow sensor is a problem while running nitrous? i've heard they can lean the car out a touch and change the tuning?
where is the best place to get a fuel pump setup for a good price that will support around 600rwhp too?? would like to get something extremely reliable (been through a few walbro 255 pumps on my old 5.0 mustang) and would prefer to buy from a shop that has been down this road many many times
Old Dec 9, 2007 | 12:51 AM
RAGENZ28's Avatar
aeromotive 1000 pump, if the speedo jumps check for shorts and make sure the battery terminals are tight I had that problem before and it actually turned out to be a bad headlight switch.
Mines a 1998 camaro.
As far as the mass air I am not sure if it leans it out, I know they should add timing.
You can change the timing using resistors on the AIT sensor, I don't know the exact ones to use though, I know there is a free mod to add a degree or two of timing with that method.
So I am sure if you had a certain resistor to trick the computer into thinking the air was on the warmer side instead of cool it would pull timing instead.
Old Dec 9, 2007 | 10:46 AM
DITCH THE GRANETELLI MASS AIR IMMEDIATELY! put the stocker back on. people are going plenty fast on the stocker.
if your car detonates the knock sensor will pick it up and pull timing.
devote a couple hours to researching all of your questions on here (search)
Old Dec 10, 2007 | 11:50 AM
thanks guys, i've found the answers to pretty much all my questions on here, i used this site to build the kit
i'll put the stock MAF back on and i'm planning on getting this fuel pump kit, i'm still looking for a comparable kit with the aeromotive as i've not found walbro pumps to be the most reliable:
http://www.texas-speed.com/shop/item...d=640&catid=10
i'll be putting it on the dyno sometime in the next few weeks and i'll update this thread when i do with how it went, i'm pretty excited, just the 50 shot made a BIG difference
Old Dec 18, 2007 | 02:03 PM
Ruckus46Gt's Avatar
About The Speedo Slip Could Your Clutch Be Slipping
