402/NOS 90mm plate with a lean spike...
Hey guys, I went back to the dyno today to check on my nitrous system to make sure everything was looking ok before getting out of control with the spray...
My "plan" was to make a pull on motor, then a pull on a 100, and if all looked well, a pull on the 150 pill....
On motor the car went 524/490. Beautiful a/f curve at 13.0:1 at the tailpipe.
On the 100 shot(NOS plate jettings)the car went 615 but had a lean spike and an overall a/f curve that approached 13.1:1 at the higher revs.
I decided to change the fuel pill to the 150 pill while staying on the 100 nitrous pill. This setup, had a smaller spike, went fat(10.3:1) from4k to 5k, and then began to lean to 12.5:1 from 5,500 on to 6,300.
We then fattened the a/f on the N/A tune and somewhat stabilized the upper rev a/f to 11.7:1 nearing redline.
My isssues: the lean spike on nitrous hit, which I may be able to avoid by shortening the fuel line from the nozzle, or adding fuel to the n/a curve at that rpm. My other concern is being limited to the 100 pill, as I wanted the "ability" to spray the 150 pill if I felt froggy......
My fuel setup consists of 42lbs inj., Racetronix pump/hotwire, and stock rails. Fuel pressure does have a momentary drop when the spray hits, but immediately recovers and stays rock solid for the rest of the pull...
Should I look into fuel rails, or will that not solve my problem? I will be ordering a shorter fuel line to the noid to help with simultaneous delivering of fuel/nitrous.
Thanks for the thoughts!
Alan
Alan
Robert
I Would Look To Fuel Rails Anyways With The Power Your Running, Wont Hurt. I Went To A Victor Jr And Bigger Rails Just For The Insurance That I Wont Have The Problem. Good Build Though, Let Us Know How It Works Out.
the initial "spike" is nothing to worry about, it is normal, i would be more conserned about it leaning at the higher rpm's, sounds liket the fuel system is not keeping up.tho you do say it stays rock steady pressure.
Robert
