Nitrous Gains
Old Mar 13, 2008 | 11:04 AM
2000whitec5's Avatar
Default Nitrous Gains
I have a H/C C5 corvette making 485RWHP N/A goes 10.6x @ 127 .. If i was to spray a 100 or 125 shot what should i expect to pick up in ET ? is there any rule to figure that out . Thanks Joe
Old Mar 13, 2008 | 12:22 PM
any guess welcome
Old Mar 13, 2008 | 01:03 PM
1lejohn's Avatar
I would think about 3-4 tenths, and 5-8 mph. Will you be spraying out of the hole? Y our car runs strong on motor already. I pick up around 4-5 tenths and 9-11 mph on a 150 shot. Thats with a .4 or .5 sec delay on launch and not spraying between shifts.
Old Mar 13, 2008 | 01:15 PM
BOLO's Avatar
Wow! Thats some good power. Good times aswell, for N/A. I would think w/100-125 shot, should be in the 9's no doubt. Traction plays a big key here also. Good luck.
Old Mar 13, 2008 | 02:22 PM
GregWS6&z28's Avatar
9.8-9.9, trapping 135-136, im guessing
Old Mar 13, 2008 | 02:31 PM
i was thinking of setting up to spray from 2nd gear on using a control unit .. I wanted to get close to the 10.10-10.20 area .. dont have a full cage nor do i want one .. but still would like to run a 10.00 class just trying to see if a 100 shot could give me .3-.4
Old Mar 14, 2008 | 09:36 PM
Robert56's Avatar
Spray it out of the hole and high 9's are very doable.
Robert
Old Mar 15, 2008 | 09:27 PM
biggdogg's Avatar
your gonna have to spray it as soon as you can and as long as you can to hit high nines i know been there done that it took me a 402 with a 200 shot to hit high 9s i have about 650 horsepower to the rear wheels.Good Luck.
Old Mar 16, 2008 | 03:13 PM
streetvet's Avatar
Robert
This will test your tranny & rear more then you think. The power gos right to the wheels. A 150 shot in good weather, 200+ in the summer . You should pull some timing too.
Congrats on your win Joe ....
See you next week.
Old Mar 16, 2008 | 03:39 PM
Robert56's Avatar
See you next week.
Very true, but a little slip in the tires goes a long way in surviving. I hit mine every time with a 5500/6000rpm clutch dump and as high as 665rwtq at 3500rpm (about 250 passes). Only broke a stock output shaft on drag radials. It's that dead hooking that can be a killer. So, yes we have to keep breakage in mind at these levels and if ya can't afford some repairs well maybe launching easy is the answer.
Robert
