help, FJO nitrous mini controller
The large ground is good.
Here are my current settings...
For example if your using a 100HP, shot don't try and ramp to 50% for only a 50 HP shot. I hope this makes sense.
It's a little hard to understand but it works like this. "Stage 1 will.......... :insert message selected in pulldown: ....." Right now, you have "Stage 1 will activate with 12 volts" So unless you've got the arming switch also sending some juice to the input #2 wire, it's not going to work.
The input #2 wire is used to select between, or activate the second stage using the pulldown menu. I have both "stages" of mine wired together and use the that pull down bar with a switch that sends power to "Input #2". Both of my stages look identical, but one has the 1st gear lockout box selected. I use my input #2 as an on/off 1st gear lockout switch.
Also, if you uncheck the RPM box, you can test the system out with the car not running with just the key on. You can hear the solenoids clicking from inside the car. Pull your fuel pump fuse and let the car run till it dies out, then turn the bottle off. This way you won't fill up the manifold with fuel.
Here's the controller transam.
http://nitrousoutlet.com/catalog/pro...product_id=952
I have my ground on the control side of my nitrous relay feeding into my shutdown switch to kill the system. I have my shutdown switch set up provide a ground until a lean condition, works like a charm. This leaves my input #2 set up so I can switch between 2 different FJO configurations on a single kit.
