Who fills their own bottles?
For the guys that fill their own bottles, how do you do it? I am thinking of just trying the freezer method before I go buying a fill station. I am tired of driving to get my bottle filled. Also can you "top off" a partially filled bottle? Like lets say I make 2 or 3 runs with the nitrous so my bottle is at say 6-7 lbs(10lb bottle), can I stick it in the freezer and then pull it out and put 3-4 lbs in it?
Also for guys that have a fill station, was it worth it? Is it that much easier to fill a bottle vs freezing it? I don't mind waiting for the bottle to chill.
![Red face](https://ls1tech.com/forums/images/icons/icon11.gif)
12" -4 line and a scale, I never let the bottle get empty pop it in the freezer for 30mins and top it off, just dont over fill it too much.
I have posted more details/tips if you search my name
I am going to be using the freeze and fill method soon. I can't wait. It is going to save me a ton of money and time!
Sorry to hijack, but for the line going from the big bottle to the nitrous bottle both connectors are -4?
Race your car!
I want to start filling my own, I've been looking around at pumps and all that but they're gonna take a good compressor for an air supply and whatnot.
The gravity system seems like it will work, I think that there are stands that you can buy to prop a mother bottle upside down isn't there?
What about a shutoff, couldn't a 1/4 turn ball valve shut the feed off going into the 10 lb'er that goes into the car? I remember reading a thread on yellowbullet about it, guys were getting 55 lbs from their local gas company for like 110 bucks of something, I'm like yeah, I need to get on that and stop paying 4 to 5 bucks a lb LOL.
Race your car!
Thing is there's a local stereo shop near my home that sells nx stuff to ricers, and they have to drive a 1/2 hour at a min to fill a bottle, so I may be filling alot of bottles ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I don't care about lease fees, if I get s fill setup chances are I'm gonna be filling ALOT of bottles.
I figure at 4 bucks a lb I'll be the cheapest guy around and chances are, one of the only guys around
Gees. Here to get a bottle filled it runs you $6 a pound. If I get my own supply it will cut that in half, saving me a ton of money!
So if I order a line with a -4 fitting on each end I should be good to hook up to the big bottle and my 10lb bottle?
Not much. I am going to do the freeze and fill method so I will not need the refill station. All you need is a bottle, which is about $60 a year, and a digital scale. I believe that is all you need.
You have to set up an account with Airgas, etc. It takes a little bit of time. It is getting expensive anyway. I get my big cylinders from Airgas (only supplier), and it cost me $217 with me picking it up. So, I end up selling it for $5.00 a lb to recoupe my cost for driving to Airgas, my pump, time, etc. Freezing is easy, but it takes a pump to get every drop out of the cylinder. Also makes life easy when customers are in a hurry and didn't freeze their bottles.
http://www.louisvillemustangs.net/fo...117#post471117
Here's a used fill station for sale if anybody is looking for one?
MOAR INFO!!!! I would love to start doing this myself. I have a buddy that works at an Airgas here intown so I might be able to get the hookup with that and I have about 3 freezers at my disposal.
There are several pump choices out there. I went with the Cold Fusion pump kit. Comes with everything you need. If prices keep going up though, I'll be selling all my nitrous stuff and going Forced Induction.
you are heading in the right direction refilling yourself; always have spray anytime and make some coin on the side (get various adapters if you will)
my reco....
when it's all said and done, do it right the first time and take a look into NX's system. stand,pump, SAFETY valves so ya don't freeze ur fingertips off when removing it as spray gets stuck in the feed line. plus they have a dig scale so you know exactly as general guage scales are often off a LB or two. Plus NX gives a big Bad *** 10ft banner to hang in the garage![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
regarding spray....
look for welding distribution firms (sell equipment to various shops, etc) google around, they are all over, or ask a machine shop/mechanic/welding supply store who their distributor is, they will be glad to give a referral makes em look good....if you go with a system that needs a stand to invert the mother bottle upside down MAKE SURE THE FEED BOTTLE DOES NOT HAVE A SIPHON TUBE. Some newer ones you will rent will have it stamped on the side, the older ones you will occasionally get dont - hit or miss but always ask and ask again. Getting an account is nothing, same as filling out a credit app. Or just tell them you don't want terms (easier) and open the acct on credit card or cash basis. When i first got my kit i had the kit, the acct, terms, and two mother bottles the same day.
AND most importantly CLEARLY state your are seeking automotive grade spray! They call it NY-TROUS. so you don't look like a junkie tryin to score
but having ur own station makes ya an addict anyway![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
hope this helps, PM me if u cant find a supplier. the firm i work with distributes nationally i can ask them for a reco in ur area.
my reco....
regarding spray....
I called Airgas this week, they want $224 for a 55lbs bottle. Which saves me money but not as much as was hoping. I am going to go the freeze and fill method for now and if I keep the nitrous I may go to a fill station.(might be changing out my LT1 for an LS1 turbo set up this winter!) I like the nitrous but that bottle sure does empty fast! LOL
Guy
Guy
