Forged LT1 383, AFR LT4 Heads, Solid Roller Lifters, Jesel Shaft Mount Rockers & more
All prices include shipping unless otherwise stated. Shipping is to the continental U.S. sent ground via the carrier of my choice. I will ship internationally and to Hawaii, Alaska and Puerto Rico if you pick up the extra charges.
I accept paypal and money orders. If you are local I’ll be willing to meet and will accept cash and deduct shipping costs.
If you feel the prices are out of line, please feel free to make a reasonable offer. If you have questions or concerns please PM me. It is the quickest way to get in contact w/ me. If you email me I may not respond to you for days.
SOLD Motor
This motor is assembled and has never been run. It was built to withstand large amounts of boost. At this point I will not separate the components. I have included the p/n’s and prices of all the parts in it for reference. If interested, I have the build sheets for the motor. Please PM me and I will send them to you.
Fresh LT1 383 Shortblock - $3,500+shipping
Bored & honed 0.030” over
Align bored and honed
Clearanced for 3.75” stroke crank
Zero (neutral) balanced
Filled with hardblock to bottom of cooling passages
4 bolt splayed caps (includes upgraded front cap) - $300
Zero deck
Lifter bores aligned
Federal Mogul cam bearings (FEM-2100M) - $40
Callies Stealth crank (3.75” stroke) - $1,000
JE pistons w/ full floating pins and spiral locks (JEP-130989-8) -$812
Lunati Pro Mod 6.0” rods (LUN-LAD1) - $740
Federal Mogul main bearings (FEM-139M) - $53
ARP main studs - $65
ARP head studs (ARP-134-4001) - $134
ARP cam bolts (ARP-234-1001) - $7
Federal Mogul rod bearings (FEM-8-7100CH) - $55
Rings – Childs & Albert Zero Gap (RS-43Zx4.035) - $150
ARP rod bolts - $60
Screens and magnets installed in lifter valley
All new freeze plugs and miscellaneous plugs installed
Pictures can be found at: http://s701.photobucket.com/albums/w.../Forged%20383/SOLD
Heads
I have the original invoice for these. If interested, please PM me.
New AFR 210 LT4 - $2,150 shipped ($2,640+shipping new)
CNC and custom hand porting from AFR
2.08” / 1.60” Manley valves
Angle milled to 58cc – you will have to have your intake machined to match your block and heads. Any competent machine shop can do this.
Pictures can be found at: http://s701.photobucket.com/albums/w...20LT4%20Heads/
Cam, Lifters & Pushrods
Custom ground solid roller Comp Cam on small diameter base circle - $200 shipped
Part #: 07-000-9
Grind # LT1 4349/4386 R114.0
Lift: 0.594” / 0.594” w/ 1.5 rockers, 0.643” / 0.643” w/ 1.6 rockers
Duration @ 0.050” lift: 258 / 268
Lobe separation: 114.0 degrees
(All specs for cam installed on 110 intake center line)
Pictures can be found at: http://i701.photobucket.com/albums/w...7/P3290001.jpg
SOLD PENDING FUNDS - Lifters - SOLD PENDING FUNDS
New Comp Cams solid roller lifters (873-16) - $350 shipped (new $480 http://store.summitracing.com/partde...6&autoview=sku)
http://i701.photobucket.com/albums/w...7/P3290007.jpg
http://i701.photobucket.com/albums/w...7/P3290008.jpg
New Hardened pushrods 7.750” long - $50 shipped
]http://i701.photobucket.com/albums/ww13/rbe17/P3290016.jpg
http://i701.photobucket.com/albums/w...7/P3290017.jpg
Oiling System
SOLD New Moroso oil pump (MOR-22112) and shaft- $75 shipped, (new $110 http://www.outperformanceshop.com/pr.../mor-22112.htm) SOLD
http://i701.photobucket.com/albums/w...oil_pump_1.jpg
http://i701.photobucket.com/albums/w...oil_pimp_2.jpg
SOLD Used Canton drag race pan - $200 shipped
Has return port for blower or turbo drain back line SOLD
Pictures can be found at: http://s701.photobucket.com/albums/w.../Canton%20Pan/
SOLD Jesel Shaft Mount Rocker Arms
Jesel shaft mount rocker arms in 1.6 ratio (KSS-336060) - $725 shipped (new $891 http://www.jegs.com/i/Jesel/549/KSS-336060/10002/-1)SOLD
Pictures can be found at: http://s701.photobucket.com/albums/w...unt%20Rockers/
New 83 lbm / hr Low Impedance injectors - $300 shipped
Pictures can be found at: http://i701.photobucket.com/albums/w..._injectors.jpg
SOLD New Double Roller Timing Chain - $45 shipped
Pictures can be found at: http://i701.photobucket.com/albums/w...ming_chain.jpg SOLD
SOLD - New Felpro 1074 head gaskets
- $40 shipped (pair) SOLD (new $38 each http://store.summitracing.com/egnsea...700+400101+115)
These were installed, but the motor was never run so they have not been heat cycled at all
http://i701.photobucket.com/albums/w...7/P3290009.jpg
http://i701.photobucket.com/albums/w...7/P3290010.jpg
Misc
SOLD Used ’95 LT1 Timing Cover - $45 shipped
Has hole blocked off for water pump drive shaft, but can be easily removed
http://i701.photobucket.com/albums/w...7/P3290005.jpg
http://i701.photobucket.com/albums/w...7/P3290006.jpg SOLD
Used '95 LT1 Timing Cover - $45 shipped This has the opti hole welded up, but the water pump drive shaft hole is open. New water pump and front seals.
Pictures:
http://i701.photobucket.com/albums/w...7/P4190003.jpg
http://i701.photobucket.com/albums/w...7/P4190004.jpg
New Rock Valley Trap Door - $45 shipped
http://i701.photobucket.com/albums/w...7/DSCN2947.jpg
http://i701.photobucket.com/albums/w...7/DSCN2948.jpg
New MSD coil p/n 8207
http://i701.photobucket.com/albums/w...7/DSCN2757.jpg
SOLD - Used MSD RPM Selector p/n 8670 3,200-5,000 RPM - $35 shipped - SOLD
http://i701.photobucket.com/albums/w...7/DSCN2737.jpg
Used Air Bags - $45 shipped
http://i701.photobucket.com/albums/w...7/DSCN2952.jpg
SOLD - Used Jacobs Mastermind Nitrous Controller - $125 shipped -SOLD
Pictures:
http://i701.photobucket.com/albums/w...stermind_1.jpg
http://i701.photobucket.com/albums/w...stermind_2.jpg
Smartspark – make offer
http://i701.photobucket.com/albums/w...smartspark.jpg
Valve Covers
Tall, polished covers. Clearance cut for alternator made, but not welded. These clear the shaft mount rockers above. Baffles included. $65 shipped.
Pictures:
http://i701.photobucket.com/albums/w...7/P4190006.jpg
http://i701.photobucket.com/albums/w...7/P4190007.jpg
http://i701.photobucket.com/albums/w...7/P4190008.jpg
B&B p/n 79605 ($180 new) - $125 shipped - cast aluminum, clearance for 1.6 RRs.
Pictures:
http://i701.photobucket.com/albums/w...7/P4190001.jpg
http://i701.photobucket.com/albums/w...7/P4190002.jpg
Please feel free to check the pictures. I’ll be adding other items as I get pictures taken.
http://s701.photobucket.com/albums/ww13/rbe17/
Thanks,
Steve.
SOLD Motor
Zero deck
ARP rod bolts - $60
Heads
Part #: 07-000-9
Oiling System
Misc
Pictures:
Pictures:
Valve Covers
Pictures:
Pictures:
Thanks,
Steve.
