Orygun guys?
#5562
I got the motor from pick a part down here. It has 85k on it.
Tim: I'm going to as fast as I can and for the smoke. Let's just I'll throw a James bond mod on it just for you..lol..
Joe: you don't have to stroke it bro. There is a turbo truck that has 1,000 plus whp without stroking it, only time will tell. But I'll tell you this, turbo cost way to much right now.
Fury: we can be twins..lol
Also the weight difference is only 80lbs..
#5566
#5570
tyler, i wont have my motor back for a coiple weeks, but hopefully when i get it itll be a week at most till its running again....got soooooo many other projects going on with the car while its down, lol i have no idea what to work on! and im waiting on atleast 20 orders from ebay, summit etc.
anyhow, ill see you monday when you come get the rotors
#5572
I basically ran 108 and change all night no matter what I did and 13.4-13.8 - based on my 60' time which was still a best of 2.2.
I had a best freak run of 13.4 @ 111 with a 2.2 60' - so the same time as my best but with 3 more mph
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
mathematically I should be able to spin 4th to ~118 but i'm running into the rev limiter at ~106-107 and having to grab fifth which is also hurting me on the big side.
#5575
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#5577
It's SUPPOSED to be 118, i've done the math on every online calculator and myself, i'm not sure what's going on but 4th is rev limiting at ~105-107 according to the mph indicator at PIR. Maybe I should grab my lappy and go log it and see what it is actually doing at the top of 4th...
#5578
Can you run a taller tire on that thing? Might need to do a gear change anyway though since it sounds to me like you'll be pushing what you've got. Speedo might also be off a tad bit causing it to hit the limiter.
If it makes you feel better, my V6 is faster
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#5580
I've gotta figure out my issue, I know the GM pcm might have a slightly different tire size but I don't believe I have a speed limiter anywhere in place that should be getting in the way.
I need to log a 4th gear redline pull and see what the GM PCM actually thinks is going on and troubleshoot from there. I shouldn't have a problem running 4th to the end of the 1/4 and pulling an even better MPH at the lights.
I don't doubt the v6 is faster, we'll see how it goes once i've got my slicks on next weekend...
