Orygun guys?
#7441
Okay check it out. I have an 02 cummins 2500 pick up, and it's got a 5" MBRP exhaust, K&N cold air kit, edge chip, and a billet HX45 hybrid from BD diesel, and it always smokes just a little puff when you jump the throttle from a stand still. So last night we wired up a smoke switch in it! On the map sensor ground/5 v wire, and this thing smokes like a freight train now!!! Pours black smoke for blocks! I love it!
#7442
#7443
#7444
Mike
#7447
sooo here's the newest rendition lol
and i didn't like the way the B&M ripper has the rubber o rings that make the shifts "softer"...... sooo i took some chromoly tube, fit two pieces together, pressed one into the shifter, and TIG'd the other one inside the other, then drilled and tapped it for set screws, now it's SOLID!! if i miss a gear now.... it's because i'm driving like a woman!! not the cars fault lol i'm gonna paint the **** black shortly.
![](http://i71.photobucket.com/albums/i134/charlie6178/Mobile%20Uploads/IMG_1216.jpg)
#7449
Yeah went out to source and they hooked me up with the steering stabilizer, the updated just able track bar, and the track bar SSI conversion plate. I did all of that, new ball joints, tie rod ends, and a leveling kit right when I bought it. It drives awesome now lol
Mike
#7459
We went to the lake to try the bird out with cutout and new clutch! Turn up the volume and enjoy is all I gotta say!!
http://www.youtube.com/watch?v=AhFeL...ature=youtu.be
