Can I get this set up to Pass the WA sniff test
So I am in the proccess if throwing a stockish lq4 botton end with a set of ls3 heads and intake into a 93 YJ jeep with a 4l70E trans with a 2700 stall. I am looking at a cam from Texas Speed
Texas Speed Torquer V2 232/234 .595"/.598"
The motor will be a gen III using a 24x reluctor wheel, I dont have the ecm yet but my question is can I get that cam to pass the sniff test in Washington with a good tune. I dont mind having to get a bit creative to get it to pass. THis will be mainly for sand and any unexpecting 5.0's in the area![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks for the input
There is no way a 230 something cam will pass a IM240 sniffer test in WA or OR. If its an OBD2 car its a cake walk, I can even write the VIN into a GM PCM, I did just that today in a 97 wrangler with a LQ9 6.0L with a small cam. But that is a OBD2 scan tool test and that is it. If you install a set of CATs and a much smaller cam it will be pretty easy to pass. Besides if you are doing this in a Jeep why so big of a camshaft? Its going to get lousy performance at crawling speeds. Most Jeep dudes go with a pretty small cam, something like an old LPE GT2-3 cam is a very good choice for low speed drivability and low end torque.
well this jeep will never crawl
i am building it for street queen use and for blasting up the dunes i wanted some power to be able to spin the 15" paddle tires that it will be running while in sand.
Will do and I appreciate all the input, I am new to the ls world but not to the SBC, I have a gen 1 forged 383 with afr heads, Gen 7 and a F1a Procharger that I got to pass with 80lb injectors running a 220/228 @50 cam
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
