spraying light over dark??
step 1 spray black
step 2 apply decal
step 3 seal entire panel
step 4 spray the color coat
step 5 clear coat
the 346 will be black and the rest of the panel will be silver
Step 1 paint just enough of the hood black to lay the decal
Step 2 apply decal
Step 3 spray sealer
Step 4 spray silver
Step 5 after silver dries pull off the decal & spray whatever i want inside the decal shape which will be black
Step 6 spray clear coat
that right now? sorry for the confusion
when you're talking about primer, sealer, and clear... primer is kinda irrelevant because you're sanding off a lot of what you spray on (assuming you prime/block/prime/block/etc). Sealer you want one good coat, maybe two medium coats.. but that depends on the recommendations of specific sealer you're actually using. However.. spraying black first... i wouldn't bother with sealer.. black basecoat is an excellent sealer. Clearcoat you can get crazy if you want, but usually 2-3 coats is just fine. Just take your time.. do it right.. and remember a good paint job is all in the prep work.
After you prime it you need to sand it smooth.. Using a sanding block is generally the way to get the best results from sanding.. Hence the term blocking
