Inner fender holes
I recently did the wiring mod on the inner passenger fender. Now my inner fender looks like swiss chesse. I started to fill in the hole with my welder and thought it may be better to fiberglass the inner fender? Any thoughts or ideas on that. Good, bad. I am all eyes.LOL
Here are some teasers pic of the fenders getting welded up. I am going to fiber glass over them to get a real smooth look.
Before, swiss chesse look
![](http://i296.photobucket.com/albums/mm194/RsSean/DSC00643.jpg)
Getting there on these
![](http://i296.photobucket.com/albums/mm194/RsSean/DSC00651.jpg)
another look
![](http://i296.photobucket.com/albums/mm194/RsSean/DSC00650.jpg)
O the battery and the PCM were not hooked up while I was welding either.
another look
OK I will see what it looks like when I get done grinding it smooth. Body filler won't crack from the heat of the engine? I would think it would that is why I said fiberglass. Or that dura-glass body filler with strands of fiber glass. I guessing it is the same thing is the kity hiar that was mentioned above.
If he were to remove the fuel lines from the stock location and reroute (as seen in the last pic), leaving that gaping hole that LT1's have, how would you cover that up? Welding? Bondo?
