Dealership repaired sail panel several times and it keeps doing the same thing...HELP
have a 02 SS noticed that the paint was doing the wrinkling crap and bubbling like they are known for doing in about 07, i told them they should replace it and they didnt want to listen. it has now been repainted a total of 6 times it looks great for a few months then starts looking like **** again. i dont know what to do this is the place i purchased the car from and they say they dont have the right equipment to replace it.
what should i do?
what should i do?
what should i do?
what should i do?
There was NEVER a recall on this part. There was a service bulletin. Your vehicle had to fall into a certain year for the individual dealership to even consider replacing it for free for you, otherwise, like most people, you would have to pay for it out of pocket. Last estimate I received was a little over $1,000.
From the sounds of it (and correct me if I'm wrong), the reason why it keeps bubbling is that you are having the dealership re-paint the panel. To understand why this keeps happening you have to understand why it happens in the first place. GM used **** poor glue to originally tack on these panels. The glue will forever continue to seep up and destroy whatever new paint you decide to put on there. You will have to replace the entire piece, and paint it to get the full job done.
from the sounds of it (and correct me if i'm wrong), the reason why it keeps bubbling is that you are having the dealership re-paint the panel. To understand why this keeps happening you have to understand why it happens in the first place. Gm used **** poor glue to originally tack on these panels. The glue will forever continue to seep up and destroy whatever new paint you decide to put on there. You will have to replace the entire piece, and paint it to get the full job done.
Seriously guys, there are three links for it right off the bat in the sticky for this section
https://ls1tech.com/forums/paint-body-work/1103895-your-answers-here-look-here-first-common-questions.html
. . . It's NOT a recall . . . There is a TSB.
You CANNOT "fix" the problem. You must REPLACE the roof hoop in it's entirety. Unfortunately the glue that holds the roof panel on, is having a chemical reaction to the material of the hoop, and is basically dissolving it from the backside out.
The Stealer who services your cars needs to be bitch slapped . . . pretty ignorant on their part to keep "trying" to fix something the GM has told them won't work . .
This is not a NEW issue . . . .
No joke ^^^, This has been discussed over and over and over again and then over again
This is what they must do
https://ls1tech.com/forums/paint-bod...-yourself.html
i know it has been discussed multiple times but my problem is a little different, the dealership denys ever hearing of the problem thats why they keep painting it ive told them whats wrong about the glue and they dont beleive me i just want something that proves im right...
guys listen too (ItsNotStock) i have a friend that owns a zl1 and another with a hot rod edition i wont go into details but it had to be replaced , its the adhesive glue it will continue to seep DO NOT waste your time and money repainting it has to be replaced period it will continue to mess up i promise you i know first hand what my high end owners were told by gm big wiggsand what they had to go though, it has to be cut off and the adhesive removed and a new one painted and put on , LET ME MAKE THIS CLEAR , IT WILL NOT WORK TO HAVE IT SANDED AND REPAINTED ITS THE ADHESIVE HOLDING IT ON THAT IS GASING THROUGH IT ,(THE ADHESIVE HAS TO BE REMOVED) , GO TO THE STICKEY AND READ MORE , now about the dealer they are sales man that dont know every knook and cranny of every model car , IF YOU TAKE IT TO A DEALER AND THEY SAY THEY WILL FIX IT THEY ARE TAKING YOUR MONEY BC THEY ARE ONLY GOING TO SAND AND PAINT AND THATS NOT THE PROBLEM
Also, here is a link to the info: https://ls1tech.com/forums/paint-bod...formation.html
what should i do?
what should i do?
Roger - I have all the stuff ready to go for this, but I need to find time to get it in the shop and just get it done. I can't wait to be done with these stupid bubbles.
