Broken bumper lip
But if youre interested in fixing it yourself, here's what you should use for flexible plastic panels. Will require paint after fixing though..
https://ls1tech.com/forums/paint-bod...ill-holes.html
the first and most important thing to remember is identifying the type of plastic, inside you will see the ISO code, which will say TPO/TPE/TEO/PP/ POLYUARTHENE IS ALWAYS YELLOW, ABS is used on saturns, and on some extrior parts on other cars as well
TPO/TPE/TEO/PP are all thermo set offlien type plastics which always always needs a adheshion promoter for anything to stick, plastic welding if fine and works really well
so now you have the plastic known, oh look it`s tpo plastic, and it has one big *** hole in it............no problem
using a D.A. is fine but through out the yrs i have found that lightly grinding BOTH sides of the plastic not just the backside, works allot better, and i mean with a small die grinder and lightly grinding just to get the paint off and rough up the plastic
i personally love using fusor products, gm to ford all use fusor, and the extreme plastic repair is a great product, if used in the wrong applications its not going to stick to nothing hence the use of the adheshion promoter
more in a few
clean the plastic before applying adheshion promoter and or a repair material
our hands are oily and dirty and greasy and if not cleaned your repair can fail, so if you do not have acsess to plastic cleaner you can use a amonia free glass cleaner to clean the plastic before anything goes on
with a hole this big and with both sides of the bumper and the broken part both sides are beveled i would plastic weld in the piece first, not only is it for strenght but it keeps it in place when you applying the material
once it cools down, clean it off again, then apply the adheshion promoter and it has to dry for 10-15 mins, it has to dry that long
once the time is up go ahead and apply your repair material to both sides of the plastic, i leave it bond for 24 hours, you dont have to products dry faster but its my habit and it works well
come back the next day use your D.A. with 80, feathering the repair, again clean it off, apply adheshion promoter, apply the finish coat<again fusor 114, i start off with 120 then i block with 120, if ya need more apply more the norm is about 2 coats of fusor 114
the primer there is no need for flexable primer, i use ppgs ncp 271, but again i use a adheshion promoter then i apply primer on plastic it helps
so thats the correct i have been doing plastic repair/custom for yrs doing it the way i just typed out
for a guess on cost for this type of repair 500-750
