coverter lockup at WOT
How many people have tuned there ecm to not lock the converter at WOT. how much et or pwer did that cost? im just curious becasue i have my vig3200 converter set not to lock at WOT. from the factory the car is set to lock at WOT @ 95mph i believe(LT1).
Now that I have a Circle D, I plan to lock it around 120mph in 3rd, to avoid hitting the rev limiter at the end of the 1/4 or having to shift to 4th.
I tried measuring the hp difference this past Saturday on a dyno, locking it at the start of the pull, but it still dropped out of lockup when I went wot, so I need to figure that out, before I can get a hp number for the difference.
It slipped; and it will do the same thing int he real world as well.
https://ls1tech.com/forums/automatic...explained.html
About halfway down the first page.
I was making 543 hp.
Their clutch surface area is supposed to be comparable to a manual trans clutch surface area.
I need to recheck my tune for any other settings/tables that would release the tcc clutch, just to make sure that's not a factor. Pretty sure I hit all 4 tables (normal, cruise, hot, performance). Seems like there's another setting that hides out somewhere, I just don't remember off the top of my head.
I haven't done many at all high HP LT1s, but the LS1's unlock if they slip right away. It could be something in your tune as well though.
Says he saw a 50hp difference in the 850 hp range.
https://ls1tech.com/forums/10546593-post9.html
That way the converter internals can buffer the rpm change, instead of the trans trying to instantly drop the engine/converter housing rpms on the shift.
When I was still driving mine on the steet I played with that at the track, made no difference in ET or MPH. Some cars do pick up at the track, depends on power level and car weight. Usually just a little MPH. Mine just sounded like another gear change with a 3600 converter. Turbo cars often love it, but it takes a converter built for it.
