Anyone lean out inj flow table to suit pressure?
42# inj @ 43.5 psi which is approx 50# @ 58 psi. My current 36# ers are @ 107% duty cycle. I want to lean the flow rate table out in order to reduce the 50# effect of the 42# ers. Anyone done this successfully? Figure so long as they're not below 62% @ WOT, should be good & that leaning out the flow rate table can get 'em there. Please comment.
Thanks
1 Post
You are going to need to go over the fueling with a wideband! You can't just change the IFR table and assume its good throughout... not sure if that is what you meant by "I will need to change the OL fueling table".
I don't understand exactly what you are trying to to ask, but I will try and answer. Are you running 42lbs injectors rated @ 43.5psi with the flow rate tables calibrated for 43.5psi? If you are you need to adjust the tables to the fuel pressure you have. (more than likely 58-60psi)This should lean out the engine and you might need to tune again. But if you are asking if your duty cycle will decrease by adjusting your flow rate tables, then the answer is yes. But the injectors will not flow any more than they are designed to. If you have the wrong injector flow rate tables in your calibration the PCM is going to command a pulse width for the injectors you program in the PCM. If you have the 42lbs injectors with the flow rate tables set for the 43.5psi scaling then you are probably running rich right now. Adjust accordingly and you should see a change in your trims.
I know an older thread but Im searching an issue anyways. Where did you come up with the 62% at WOT? Ive got 42# svo that are running very lean at high manifold vacuum. Duty cycle is 44% @ WOT.
