nitro daves dyno tune?
any input is appreciated!
Good Luck,
Sean
I believe "moehorsepower" on this board is going to tune the car for you. I went with the TR224 114 cam. At the time I did not have headers on there. After the 1st tune car put down 350rwhp. After at least 7 times of retuning the car put down 360rwhp. I would highly recommend moe for the tuning. He did an awesome job for me.
hey "abate1224" you almost have the exact same setup im going for. I have the 224/224 114 cam and im going for the NX 100 wet kit as well. What did you dyno with and without the 100 shot? Any 1/4 mile results?
Would you be able to PM me and speak a little about your setup? Im a little worried about the traction conditions in 2nd gear roll.
i drove all the way from Oklahoma (4 hours) to get my cam installed, and it was worth it that i drove there again to get more stuff installed( heads, headers, tunning)
Dave is a great guy to deal with and the customer service is the best,
Abdulla
Since he does WOT tuning on the dyno, and then partial throttle tuning (backwards IMHO), although the fueling was perfect on the dyno, after doing some crusing with the LTrims pegged to 25. When I would go WOT, instead of locking at zero they would lock at 25! This caused the WOT fueling to go down a full point (i.e. to 10.5:1).
I told Dave about the problems and he wanted me to come back up there (another testiment to his good service). So I did. However when we put it on the dyno and saw the 10.5:1 A/F ratio Moe was perplexed as to why it was so rich, and immediately blamed me for messing it up! He also claimed the reason the car surged was because I "put it in 4th gear at low speeds."
I left the 2nd time with the car in the same shape as before. LTrims pegged to 25 each, about 3* of KR at WOT, etc. I ended up spending a few hours tuning it myself. Now it drives like stock, idles perfectly right off the bat without throttle (even on cold mornings). And guess what? I can even put it in 4th gear at low speeds without it bucking and surging!
Turns out mostly the cause of the problem was from Moe apparently forgetting to change several important tables, for example Injector Offset (I have SVO 42lb injectors). I also noticed the MAF scaling was not smooth and had some strange spikes in it. There were also some less severe problems like neglecting to disable some codes related to AIR, etc.
For someone who didn't have their own copy of LS1 Edit, this would have been a nightmare and most likely I would still have the bucking/surging problems!
When it all comes down to it, the service there from Dave was excellent, top notch. I would probably still buy parts from him. However, Moe's tuning (on LS1s at least) was poor IMO. I would not take my car there again for tuning, nor can I recommend it to anyone in good conscience. It is possible this is an isolated incident, however when it happens to "you" it's the only incident that matters.
Tell the whole story here.Your car had several machanical problems when you brought it down.We did what we could to tune it.Then you drove it home and found shorts and bare wires in your wiring.Moe took off work and asked you to come back up on that friday in the morning.You showed up at 4:30 in the afternoon.You thinking you know how to tune you had been in there playing with tables.That is the only way that your fuel tables would have droped down in the 10s on air fuel like it did.I bit my tongue and so did Moe.Instead we took and retuned your car for you at no extra charge.You picked up over 200 HP FROM OUR TUNE.When we pulled it off the dyno and took it for a drive it ran great.The next day it was brought to my attention that you were in the computer again playing with the tune.When we were tuning your car you kept asking Moe (Just tweek it a little more) as a tuner Moe knows when it is right.But instead he tried the things you asked for to make you happy.You called me and said you felt cheated on your tune because Moe did not change all of the tables.Just to let you know not all of the tables have to be changed.Moe has tunned 100s of cars including other super charged cars and you are the first and only person that we have ever had a problem with.The reason why we have had this problem is because you own LS1 edit and really beleave that you can take someone elses work and tweek it alittle more.You are the one that has messed up your tune.JUST BECAUSE YOU OWN LS1 EDIT DOES NOT MAKE YOU A OVERNIGHT TUNER. Moe has spent alot of time learning his tuning capabilities and were taught by the best.Have you ever heard of Chris Bennight?
Moe and Chris have spent alot of hours together on this. I have 100% confidence in Moe or he would not be a part of Nitro Daves.Matt you are a nice guy,but in your quest of trying to make your self look like the man to your friends you have overlooked the truth.Just keep in mind that you are the only person that has everhad a problem with our tuning and then ask yourself why.I thought long and hard about what to do about you.My decision was and still is to stand behind Moe on this one.
Thanks
Dave
However, the battery terminal ground out does not effect the tune! I showed up at 4:30 because that is when y'all told me to (as I recall) you said Moe works days and goes to Dave's after work for tuning for some extra income. (If I recall correctly).
I was never randomly playing with tables. I never touched any fueling tables PERIOD. I only adjusted Idle Air Flow and IAC Park Position. I told Moe exactly which two I did and he said it was find. If he thought it could be a problem we could have easily reverted back to the original program. He didn't do that because he knew that I had fixed the idle for him!
I explained in my original post what happened with the AFR. The LTrims were pegged at 25 and this caused the ECM to dump fuel at WOT. Why don't you ask Chris B about that?
Hate to save it Dave but your ignorance has shown through like a shining star and the data will back my side of the story up.
I am aware not all tables need to be changed, no doubt. However some important ones DO need to be changed, and they were STOCK! By simply adjusting these tables I was able to get the car to drive perfectly. How do you exlain that?
So Dave, if I don't know jack squat about tuning WHY DOES THE CAR RUN TOP NOTCH NOW WITH NO SURGING, BUCKING, IDLE ISSUES?! WHY ARE THE LTRIMS -3% AND LOCK AT ZERO? WHY DOES IT DRIVE LIKE STOCK PARTIAL THROTTLE?
P.S. I don't care what my friends think, if I wanted them to think I was a bad *** tuner I would have just said I did all the tuning myself and not mention your shop.
P.p.s. I am frankly surprised and disappointed that you posted this, Dave. Oh and one more thing. I personally know of at least 1 other person who is dissatisfied with Moe's tuning. Just because they don't mention it doesn't mean they are satisfied with the tuning.
I installed some stage 1 heads and a custom ground comp cam in my 6 speed car and took the car to Dave's one weekend before his dyno was finished. Moe put a baseline street tune in it and the driveability of the car was just amazing, the car would barely stay running and would buck like crazy with anything below 2500 rpm before the tune and after the tune it drove around like it was almost a stock car, the only time the car surges now is under 1200 rpm.
I took the car back a few months later and Moe Dyno tuned the car to 425rwhp and 395ftlb's.
Nitro Dave's is a top notch facility (as you probably noticed by the large amount of positive responses to this thread)
Most of the things you said in your post are inaccurate or just plain untruthful. I could go through item by item and disprove them all but it wouldn't help anyone and I don't feel like getting into it since all is well now, it's not a huge deal.
I never intended to flame you or Dave, just wanted to put my story out there and let people draw their own conclusions. I also didn't intend to hijack the thread, sorry if it turned into a flame fest against me from the professionals
P.S. I have no ill feelings towards anyone
https://ls1tech.com/forums/dynamometer-results-comparisons/136319-my-setup-finally-dynoe-d-d.html
whats up Sean?
. That makes me glad I had nitro daves work on my car.Moe did the tuning on my car and then I put headers on there. It threw a SES light (even with a catted y-pipe) and clark reset it and it threw it again on my way to san antonio. I took it to the dealership (for other things) and they said the airbag light came on and they reset that as well but unfortunately my SES light came back on again
. I still have ZERO bad things to say about nitro dave as I KNOW Dave would gladly take care of that for no charge really and maybe even pay for MY lunch AGAIN (but im not going let that happen lol
). You really should have no reason to be upset with the tune. I understand the fact you were not truely satisfied with the tune because of the mishaps. But **** if they are willing to still help you out with more tuning to correct it then there is truely no reason for you to give bad feedback about there shop right?
Back to the main subject:
I am VERY glad with nitro daves or nitrous outlet working on my car. I would gladly take the 4 hour drive anytime for any future mods as well as moe's tuning. I have never liked putting decals on my car as it feels like im advertising (which is not my cup of coffee) but i was so glad with their work i know i wont take it off.
Hope I wont bore you again dave on my next visit. Ill have to be in your shop for over 24 hours (since ill be there for 2 days for the nitrous install.
)Nitro Dave represting. And if you've never been there you should!
Ahmed
https://ls1tech.com/forums/showthread.php?t=136319
whats up Sean?
Thanks for the good words guys. There always has to be a bad apple to a good positive thread. Glad you left happy Vince (but we would make sure that would happen anyways
)Take it easy,
Sean
Hate to be a "bad apple" maybe I should have just said they did a top notch job to go with the flow
I think by all these threads that the truth has come out...........
