oveheats in 3bar tune but not in 1 bar?
Old 07-28-2012, 09:10 AM
Bobsmyuncle's Avatar
Default oveheats in 3bar tune but not in 1 bar?
i checked all the fan settings and everything is the same. will overheat when its on the 3bar, doesnt overheat on the 1 bar. sounds weird but its the only thing i change and it doesnt overheat.
Old 07-28-2012, 10:10 AM
Moderator
jimmyblue's Avatar
So are the fans running when it's overheated, or no? That
is the first diagnostic "cut".
Maybe the 3-bar has a default "no e-fans" selection, or
a crazy low fan-defeat MPH, or something.
Old 07-28-2012, 10:22 AM
both were set at 30 mph, and on the pull down, theyre both on the "2 fans" setting.
i boiled the tstat and it came open.
Old 07-28-2012, 02:02 PM
Old Geezer's Avatar
Data log both tunes and do a compare....
Old 07-28-2012, 04:57 PM
well. now its overheating on both tunes.
ive tried the following:
stock thermostat with a bunch of holes drilled in it
160* thermostat
160* thermostat with holes
no thermostat
it has goten better with no thermostat now, i can sit for about 3-4 min but it slowly and slowly creeps up to 225-230ish
i cant think of what else it can be,
Old 07-28-2012, 06:08 PM
MUSTANGBRKR02's Avatar
Are you just now getting the car running from a rebuild? Do you have the steam vents venting to the radiator?
Old 07-28-2012, 06:40 PM
steam vents are connected to top of radiator, im gonna pull that off and make sure its flowing right now.
Old 07-28-2012, 06:41 PM
im thinkin it might not be flowing bc when i first got the car together, it didnt overheat
Old 07-28-2012, 06:53 PM
Have you bled the system properly?
Old 07-29-2012, 07:52 AM
Old Geezer's Avatar
Did you do some "beating on it"??? With forced induction, are the heads still "down on the block"??
Looking at your other posts, the overheating appears to be an ongoing problem. Add in the inj problems, I'd say it's time for a leakdown check...
Old 07-29-2012, 11:42 AM
Moderator
jimmyblue's Avatar
I do not see the answer to whether the fans are actually
running when it overheats.
