having to pull 6+ degrees of timing with ls6 intake and longtubes (2000)
I scanned it, and had ~4 degrees of knock throughout the 0.24-0.68 g/cyl area from 1500-5500rpm. To avoid having a huge valley in the table, I flashed it to a stock 2003 zo6 timing table and immediately it felt better at low rpms where it used to bog, along with less knock. I kept logging and tweaking and now have an average of 5 or 6 degrees pulled throughout the entire table.
I know 2000's have the more aggressive stock timing table, and that the ls6 intake will occasionally lead to some knock (better flow needs less timing, etc) but does it sound fishy that I had to modify the majority of the table? Looking at the 2002 timing table it looks like it still has similar timing in areas where I had to pull more.
Car:
2000 Trans Am m6
Mods:
-lid/tb/ls6 intake
-longtubes/catted Y/magnaflow
here's where I was getting knock:
my VE table:
this is what my timing table has ended up looking like (needs smoothing):
stock 2000 timing table:
Attached are my current tune, and a log before the last round of timing changes
about real air temps. At the lower end where the speed
density air mass is still a big component of dynamic airflow,
IAT affects the calculation a lot. And hot IAT says low air
mass, causing lean fueling.
Now your IAT spark adder might be a better place to do
this spark pulling, if you are convinced that cool air temps
still run right.
Improving the cooling stack (cleaning rad & condenser,
making fans run sooner, etc.) can improve the actual
underhood air temp, if you're pulling from there. The
air path particulars, here, I do not know.
Does relocating it require any changes in itself? The only table I see is the IAT spark table that pulls a few degrees from 100+ over 80 MAP
Just as a test I put the IAT near the DRL and it stayed just a few degrees above ambient, getting only a little warmer at idle. Still knocking, but I didn't make any tuning changes. Every time I log I hit few cells that get 5ish degrees of knock, not really sure where to go from here or just continue to pull timing.
You lost me with your last post, but I think your IAT timing table needs to be a little more aggressive.
I would think other people would experience the same thing though with how common my mods are, although it is really liking the lower spark off the line.
high IAT readings gives you both short fuel and long
spark, for the real conditions; both index off air mass.
A double whammy, as it were.
Since you have a condition where you're happy with
the fuel / spark, I'd work with the modifiers based on
that stake-in-the-ground. Though for me, 40F would
be unusually low as a point of refernce.
Another school of thought would be, tune for the
crappiest conditions you normally encounter, and
use the modifiers for "upside" when you find good
air.
But in any case, truth-based tuning is a good idea,
meaning you'd like sensor fidelity (along with better
air, however you can get it). IAT especially is very
subject to location (thermal input, relative weights
of supposed-to-be-sensed and can't-help-sensing).
I'm going to try running some Techron through the tank, changing plugs and fuel filter, and then starting over with my tune in the heat with the IAT relocated. As the temperature drops I'll see if it's worth modifying the spark vs IAT to run a few degrees extra when I get better air.
