hptuners wot help
Old 07-01-2004, 05:49 PM
z-ya's Avatar
Default hptuners wot help
I have mutiplied the pe talbe in hp tuners to try and lean out my wot,but it does'nt seem to be helping.I first mutiplied by .93,and then by .95,but the af stayed at 12.2.Any addvice on what to do now?TIA Mark
Old 07-01-2004, 05:56 PM
2xLS1's Avatar
Is COT still enabled?
Old 07-01-2004, 06:13 PM
z-ya's Avatar
No cot is disabled.The 12.2 is a inovate wibeband reading also not some o2 converted reading.This just does'nt make sense to me.The readings at idie and cruise look normal,ltft's are negative and o at wot.
Old 07-01-2004, 06:38 PM
TT_Vert's Avatar
are your o2 voltages changing at all? Just curious to see if the PE is even doing anything. I noticed my WOT o2 voltages to change when i changed my PE.
dave
Old 07-01-2004, 06:58 PM
z-ya's Avatar
Well not much movement on the o2 readings either, still 960-980 at wot.I'm useing the
v8 rpm pe table I hope thats the right one.Im beginning to miss my carb jets and gas soaked hands.
Old 07-01-2004, 10:30 PM
Moderator
jimmyblue's Avatar
Look to your open-loop AFR table. As I understand
things, at WOT the PCM will choose between the
richer of PE and the Open Loop commanded AFRs.
So if the Open Loop vs ECT vs MAP table sez 1.13
in a cell (13.0:1 target) and the PE vs RPM sez
1.10 (1.25*0.93*0.95, 13.4:1 target after edit)
the PE table will be ignored because the fattest
one wins.
When you log, next time try and log the Air/Fuel
Multiplier; judge whether it is what you told it
for PE, or something else (and track down what
happens to be pushing that value).
Why you'd be that far off (12.2 vs 13.0) is a
whole 'nother question, but I think if you knock
the Open Loop table, MAP>80, ECT>158F cells
down some, maybe it'll free up the mixture
reduction.
Old 07-01-2004, 10:34 PM
ataylors's Avatar
how about sharing some logs, that might help someone spot the troubles
Old 07-02-2004, 04:58 PM
z-ya's Avatar
After several logs the afr finnaly leaned out,didn't seem like it changed immediatly when I changed the pe multiplier.I drove the car twice whlile logging arf on the innovate when I started to see the change.In the end I had to richen back up because it went to 13.3.This was on the same pe multiplier that saw 12.2 early in the afternoon.Does this need to soak in to the tune or is the pe multiplier an immediate and consistant change?Maybe it was just the full moon,or my pcm is possesed.Jimmy blue your explanation my be the answer here also.
Old 07-02-2004, 06:47 PM
ataylors's Avatar
Any time you change teh fuel setting around it takes a while for the "new" readings to become stable
Old 07-02-2004, 10:46 PM
WS6 GreeN's Avatar
Is it the V8 RPM PE table, or the PE Fuel Multiplier vs RPM table that you should be modding?
Old 07-03-2004, 12:28 AM
luv2spd's Avatar
It's the pe vs rpm table
