93 c1500 turbo lq4 wont start!!
So im at the point where im close to finishing my project just need to fine tune it. Little info on my build: 93 c1500 6.0 lq4 80mm turbo 3bar efi source map, 80# Dekas, Aeromotive BRFPR, 450lph pump. it turns on for a couple seconds and dies out. Heres my tune attached if some can give me hand I would greatly appreciate it. Thanks in advance!!
My 04 OBS turbo.hpt
My 04 OBS turbo.hpt
Is VATS disabled?
That might be possible. You didn't make any changes when you put the MAP sensor in?
Usually when you put the 3bar os in it fills the VE with invalid #s. I believe it make the whole table flat 512. Youll need to copy and paste your other table in, then add some to the boosted regions. Yours may be different but when i went 3 bar on mine that was the case
doesn't let me download it.. email to me tuninglabcontact@gmail.com
So got the truck to run for a little bit and dies out. It wont turn unless i erase these codes.
P0068 map/maf- throttle position correlation
P0102 mass airflow circuit A low
P0103 mass airflow circuit A high
P0107 manifold pressure/ BARO Low
P0522 engine oil pressure sensor low
P0622 generator field terminal circuit
So i went to engine diagnostics and put no error reported for MAF and it runs for more than what it did but wont stay.
For some reason i cant upload my tune or pictures! I can email it to you guys.
