Help tuner says mechanical problems and engine builder says nothing is wrong
* The VE table is a mess. The lines are criss-crossing and jumping all over the place instead of smooth transitions.
* THe dynamic airflow is set up for MAF only, but the tune is SD. Could be causing it to fight itself.
* Transient Fuel min fuel milligrams needs to drop to 0.010. That's kind of tuning 101 for larger injectors.
* Injector flow rate data is effed. Typically is not the same value in every field. Also, 60 lb injectors flow closer to 75 at LS pressures, not 60.
Now, one observation on the mechanical side:
* Your map readings at WOT under 3500 rpm are low. Maybe that's normal for a turbo, maybe not, but all of mine at low RPM show near atmospheric pressure at WOT. Might be worth looking for an intake blockage.
* I cannot see in the logs if there is any valve float, but it does seem like power is peaking early. Have a dyno graph to post?
* Edit - if you suspect valve float, your sig does not mention pushrods. If you are running stock pushrods, get some 11/32 from manton
dyno that is rough at the top and not sure if it matches any of the logs
Last edited by The Fugitive; Oct 3, 2018 at 10:43 PM. Reason: forgot to attach the dyno graph
Spark blow-out N/A is very unlikely, so if it does it still, its likely valve float.
I'd recommend a smaller cam either way. Tuning for a large cam N/A is typically harder than tuning boost with a smaller cam. Combining them will test your tuners abilities.
Do NOT disconnect the charge pipe and try to make a pull unless you want to potentially hurt the turbo in the process.
