Change to MAF Table w/ MAF Ends?
Thanks
when you hack your maf sensor, you need to adjuist those tables... there is just 1 problem with it, you don't know the correct calibration to enter, as the maf ends alter the maf output, and nobody has the data provided to go along with that mod
Ryan
It sure does!!! I probably did about 200-300 miles worth of testing and found out that a MAF with the screen removed and/or ported MAF ends with no screen throws your Ltrims off by about 5%.
From the research that I have done, dynoing cars, and asking a few pros, the best bet is to leave your Stock MAF; Stock! A tad easier to tune and is not a restriction unless your over 450-500HP.
I fall into this catagory "450 - 500HP"...if it is throwing the LT's off by 5% then should the table be scaled 5%?
MAP cells for LTFT guidance. Like 10 & 11 if
you are set up to touch those. Forget the
0-3, 4, 8 cells as the MAF is really not too
involved there. Multiply the whole table by
1+(LTFT/100) and you should end up about
neutral (maybe add a little for luck and
environmentals).
You may have to shave on it some more if the
MAF ends' effect is not a constant scaling
across the board, but this is a start.
This method lumps all nonidealities onto the
MAF table, whether or not the MAF was the
only thing responsible. The more mods you
have tangled up, the harder it is to get all of
the various model tables properly accounting
for their individual responsibilities. That's why
having a spare, stock MAF can be handy -
one less thing to make assumptions about.
That's the answer I was looking for...sorry Jimmy you kind of lost me on your explaination...I don't have my HPtuners software right here in front of me at work. So I will go home and look at it, then re-read your post. But I am going to start with Billiumss suggestion with the 105%, and go from there.
I have heard of it being non-linear though, but once you change cams, heads, exhaust, some things go out the window.
You are exactly right, It is much better just to leave the MAF STOCK. The only thing I would reccommend is de-screening it and thats it. Though we had a LS1 on the Dyno and did a before and after A/F with and without the screen and it leaned it out a full Point!!!
