Need some help figuring out strange lean condition
running a ls7 intake manifold.
car was dyno tuned and ran great. Over the last week, the car has started to run poorly.. when data logging and using my wideband, I logged AFRs upwards of 18-19 so super lean.. this occurs under acceleration, like 19% throttle position and like 2300-3000 rpm. It’s intermittent. It happens sometimes are higher rpm.
I cleaned my fuel filter (magnafuel). Fuel pressure regulator gauge shows 58psi. Injectors are FIC 62lb/hr.
Also have a NW 92mm tb, Hooker 1.75” longtubes to a full 3” exhaust.
Yesterday I smoke tested the intake manifold for leaks. I’m doing so I removed the intake tube and unplugged the MAF.
Today, hooked my fuel pressure gauge up to see if I was dropping pressure which would cause the lean condition.
took the car on a drive and it ran perfect aside from dying when I come to a stop and hard starting..
No fuel pressure issues..
realized I left the MAF unplugged so I turned the engine off, plugged it in and cycled the key 2 times then started it. Accelerated and it went into a lean condition!
pulled over, unplugged the MAF and fired it up, and it ran fine again!
possibly dirty MAF? It’s brand new AC Delco LS7 maf maybe 350 miles on it. I do have a KN filter
In all your playing around with the air system, did you run it sans filter for any time? OR did your system have any leaks after the filter?
I cleaned it with MAF cleaner and now it is running lean upon start up whereas before it was under load about 2000rpm.
took the filter off and re cleaned and still runs bad with MAF plugged in.
p01 pcm hardware 411... put the new MAF in today, and it idles fine now but under accel it leans out again..
would opening up airflow to where the filter is (adding a headlight funnel and air vent) possibly have an effect on it??
maybe the air is too turbulent? I see some people using the honeycomb air straightener
Once again, this all seemed to start when I opened up the inner headlight hole to allow more outside air to the filter. I also added another airduct with a scoop in the bumper that feeds the filter. unfortunately, I can't cover those openings up to get it back to "how it was" before I started having issues...
ugh.. its a Nick Williams 92mm TB... I got it to replace a crap chinese holley TB that was giving me issues.... the NW TB fixed my issues I was having with idling.. doesn't have that much wear on it... I wonder if they have seals for these things??
https://ls1tech.com/forums/generatio...ms-102-tb.html
July 22 is with maf plugged in... 22 #2 is with maf failed out at 100 Hz.. not as lean but still lean at higher rpm none the less...
