Reluctor wheel failure, Maybe?
I have a misfire issue with my fresh stroker LS that's driving me mad, cylinders 6 and 8 do not fire properly and backfire like gunshots through the exhaust and doesn't allow it to idle (these aren't pops or burbles, these are 9mm without ear protection loud). Above idle, the fuel flows right out the exhaust and it doesn't backfire but it stumbles and doesn't take throttle obviously because its -2 cylinders. It has fuel, air and good spark.
Heres what I'm working with: 416 LS in my 1969 chevelle, gen 3 iron block, K1 24x forged crank/rods, wiseco pistons 13:1 all said and done, ported GM LS3 heads, stock rockers with trunion, ported LS3 intake, LS7 throttle body, 65lb injectors spitting some E85, EDIT: 240-251@.050 cam, and controlled by a Holley Terminator X Max. The Terminator is wired properly because I ran this exact setup on my 6.0 before dropping valves, hence why its a 416 now. I did not change anything in terms of locations of power and ground circuits (except to the battery, relocated to the trunk with ALL the good grounding from frame/body and leads directly from the engine block), both under the dash and on the engine block.
Base cals are surprisingly good for my dinosaur tuning ability, this thing fires up in 1/2 crank! O2 sensor is placed on the good bank (driver side) and that reads RIGHT at 8:1.
I've done the simple stuff 10x over. Grounds, EFI connections, check for power at injectors/coils, plug wire connections, plug wire order, getting both clicks on the plug wires coil-side, corresponding coil wire color to the correct cylinder, injectors plugged in right, confirming not stuck injectors, getting shocked by the plugs confirming good spark, correct fuel pressure by mechanical fuel pressure gauge as well as the holley trandsucer, changing spark plugs (TR6 @.035), then I've swapped injectors, swapped coils, swapped plug wires, changed cam and crank sensors, pinned the entire wire harness of coil/injector/cam sensor/crank sensor circuits, and found nothing that jumps out at me.
Called holley tech support, and dude said its a very unusual issue, try updating firmware to rule out "ghost" problems. Did that on handheld and the ECU, nothing.
EDIT- COMPRESSION TEST yielded 3% spread between worst and best cylinders, 178-183PSI
Heres what caught my eye: I went into the firing order of the tune, and I swapped 4 and 6. Then I plugged cylinder 4 coils/injectors into 6 and vise versa, essentially using 6's electronics on 4 and vise versa, to rule out a fried driver or extraneous failure in my ECU. And to my surprise it fired right up, my idea worked, AND that issue STAYED WITH ACTUAL #6 in the real firing order. So I started getting the idea that the ECU doesn't know where cylinder 6 and 8 are momentarily, then when it gets signal back it immediately sends spark out which by that time is during the exhaust stroke, which is why it backfires.
So this points me toward the reluctor wheel. I measured my crank thrust--.004.
NOW, I ziptied my phone to the side of the block with the camera pointing down the crank sensor hole, and i DO SEE RUNOUT ON THE WHEEL, probably .030-.040 just by eyeballing it. That's a whole lot more than the out-of-spec crank thrust measurement. BUT. My question is, why would damage ONLY affect 2 cylinders in this case given the fact the crank spins twice in the 4 stroke cycle, meaning 2 different cylinders (1, and 5) share that EXACT SAME LOCATION on the wheel? And 6-8 don't share a location on that wheel, they're 90* off mechanically, and 3/4 turn off in the actual firing order, which makes my head spin.
If I had an oscillascope with good enough resolution, I would read the crank sensor output and compare that to the sample waveform. My Snap-on Modis Edge can read waveforms but doesn't have the resolution when cranking over on the starter (looks like a bunch of pins stacked next to each other), and the engine is difficult enough to crank over by hand that i wouldn't be able to get a consistent turn speed. The car doesn't have wheels/tires or driveshaft so I cant roll it down a driveway.
I've uploaded some supporting videos I took during my troubleshooting.
PARDON MY SWEARING IN THE START-UP VID.
The videos uploaded are slow motion footage of verifying cyls 6 and 8 HAVE SPARK and are not sparking at the same time (I verified its good spark using the touch test), a start-up vid after I switched stuff between 6 and 4 along with a sample of the backfiring, and a vid of my camera down the crank sensor hole-and me speeding through the vid a little finding the runout. (The wheel on the left side edge does move indicating some axial runout).
Am I correct in my suspicion that the reluctor is what is causing my issues?
I have no issue taking the engine out and apart to put a new wheel on there (with the special tool obviously) but if I don't have to do this then I would rather not.
I'm sure other people have had it worse, but theres literally 4 things left to install on this car before I can drive it out of the garage. Big sad.
I could use some extra eyes on this! Thank you all in advance!
Last edited by kimbalmlq4; Nov 7, 2022 at 09:07 PM. Reason: Bad memory of extremely important details
Yea I didn't have time to read the whole thing but if you are suspecting a reluctor wheel problem I'd get an oscilliscope as you describe and get it working on cranking somehow.
Put it first on the crank sensor and make sure the waveform is solid, then crank the car with CAM and CRANK waveforms on the same screen and it'll be clear if they line up. I can give you a sample known good waveform to compare that to if you need. THEN, you can use a pressure transducer on the scope and see exactly where the valve is opening and the piston is closing and compare that to the reluctor waveforms and you'll know if your reluctor wheels are right. If you have a good scope you can do all 3 at once, I only have a 2 channel scope so I have to do two steps as described.
Ol' Bernie at ATS just did a fresh video showing this concept, different car but you'll get the idea:
The Aha moment starts at around 20:00 in the vid showing reluctor wheel is off (phaser wheel, but similar). You don't need a scope like his, I use a Pico 2204A I think it is with an Ebay transducer and I can get good waveforms while cranking.
Hail Bernie. Dude is a rock star.
If it's backfiring it has to be off enough to show up checking like this.
This car was magnetized from a MISSING ground causing current to go through cam/reluctor, he explains the cause and also shows degaussing, interesting stuff.
On the 24X reluctor wheels, the wheels can separate (come apart) where they are pressed together. I have seen this on a friends turbo charged truck when we tore his new rebuild down after a total failure with only 1500 miles...
Here is a thread where some one else shows it separating where it's pressed together.
https://ls1tech.com/forums/generatio...-question.html
That being said. We had another member here with a corvette that could never get his New 408 engine started. He eventually pulled the engine and found the wheel had been bent/compromised at some point. Either in shipping of the new parts or at the engine builder and they didn't catch it.... He pulled the crank, Purchased the tool and a billet wheel, Then proceeded to fix it him self. He was so happy that he was finally able to enjoy the car again. That was short lived as I don't think it had more than 1000 miles when the engine totally failed... I think He put a new crate GM LS3 So he could enjoy the car again.
Here is were he pulled the engine and discovered the bent wheel.
https://www.performancetrucks.net/fo...4/#post5511613
So heres my plan. I sent off my ECU to holley for analysis, i'm 50% certain that will fix it, if that doesn't fix it then I have no choices other than taking another look at the harness again with a hawkeye, and if I find nothing from THAT then I pull the motor/pull it apart and install the billet reluctor wheel sitting on my desk right now that I panic impulse bought. I may or may not have a LS specializing shop near me do the engine stuff because I'm sick to death of using my brain, I don't even want to look at this engine anymore. I just want to do mindless assembly and building of the rest of the car at this point lol
https://www.holley.com/products/igni...its/parts/8619
