C5 A4 strange shifting
unlocking (misfires from cam & light-mass converter)?
If it's truly shifting, check that your upshift and
downshift points, by TPS, are separated by at least
1 MPH in 1st, more in 2nd and third (up > down).
Lightly tap the brake at the same speed and make sure it isnt the converter unlocking (if its locked tapping the brakes will unlock it), if its the converter make sure you have all 3, low rpm, idle by cyl and lowropm by cyl set to 32367.
Also make sure if the gear was changed the PCM was flashed for the new gear, even though the speedo will be correct some other things will act wierd if the gear isnt rescaled.
downshift MPH are too close together (like identical)
at ~16% TPS and any little VSS or TPS "flutter" could kick it
forward & back?
With the way the scanners "decimate" the data (you see
about 1/8 of what the PCM sees, 100mS logger frame vs
12.5mS internal data period) any such "hiccups" could
have a high probability of never being shown.
forward & back?
He has the TC1 3500 torque converter, I don't know if that has anything to do with it. There is no problem with the yank converters I have tuned for or an TCI 3500 in an F-body.
intermittent in the tranny control harness? Is this
problem something you can replicate at will? If so
log the stuff that pertains to slected gear and note
whether the stutter-step is commanded, or freestyle?
Not sure how you would know if the problem was in the control harness, any ideas?
Thanks
the scanner doesn't show anything like "last commanded
shift" etc. that would point to something outside the PCM.
I vaguely remember a bunch of odd PIDs like that though
I haven't had any use for them. But if you can instrument
up for the PIDs that pertain to shift commands that should
at least separate the commanded / spurious.
Don't forget the known "get squirrely with low fluid" angle,
neither.
neither.
