A question about 02 Rich/Lean vs. Airflow with Hp Tuners
ok Here is my delema,When I auto-tap my WOT mv's my bank 1 is much lower(.865) than Bank2 (.900) by an average of .035 mv's.Now my question is do bank1 and bank2 have to be the same?It figures out to I need to go 1% more on bank1 to be even with bank2.Should I do this or leave it alone?Are they supposed to be close to the same?Thanks for your help...
Scott
Scott
There may not be a leak. Mine are always off by about that much. They were with the stock manifolds, and they still are with shorties and new gaskets. I also swapped O2s from side to side with no change. Either it is a difference in fueling on one side, or the O2 on one side cools faster because it is further downstream, or a difference in resistance or something caused by wiring. You should check everything, but you may not find a problem.
The PCM doesn't isolate fueling per bank - or if it does I haven't seen the tables to isolate banks.
My thought was to tune based upon the readings on the leaner bank to prevent that bank from accidentally being too lean if you tuned based upon the richer bank. Hmm, I think that makes sense
I have never seen anybody do it. I have toyed with the idea of doing it plenty of times. Getting it right would be pretty much "hit or miss", unless you have a wideband sensor added on each bank and tune your O2s R/F numbers until both match at most RPMs. It's not worth your time. As long as you are not getting positive trims at WOT, both banks will get the same amount of fuel (injectors permitting) at WOT. So there will be no impact on horsepower.
Originally Posted by Pro Mouse
Thank you for that info Another_User This was the Kind of answers I am looking forI Have my Recent A-Tap log and my LTerm were B1 0.8 and B2 0.0 is the .8 at wot good or is there a way I need to tune it down to 0.0?
Thanks!
Thanks!
