wide band 02 bung
i always wonder when someone types like that if they speak the same...
If you have cats, you want to place your wideband o2 in front of it so that it will take readings from an uninterrupted, true exhaust content... Cats distort wideband readings and functionality... hope this helps...
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by slow ride
This does help thanks. But it makes me wonder about the A/F reading taken at the dyno Saterday. They just put a small tube with a vacum pump in the exhaust tail pipe. they Said it just sucks it out. The A/R reading can't be correct.
I'm so sorry
I was at work, on a break and typing fast,
I did not have time to proof read the post.
so if you can ever forgive me here are a few more periods to make up for it
More Than Zero
Originally Posted by M_T_0
I'm so sorry
More Than Zero
More Than Zero
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
for scientific purposes I put a bung before and after the catalytic. I tried both and the O2 sensor is effective in both places. I cannot discern that the cat affects the reading significanly with the oxygen sensor in either location. I am using an LM-1.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Both part throttle and WOT? If so, that may solve all my problems.
