Difference in wideband and HPtuners...
Old May 1, 2005 | 05:48 PM
Phil99vette's Avatar
7 Second Club
Default Difference in wideband and HPtuners...
I started logging the wideband for VE tuning and noticed that the HPtuners is showing A/F .2 more than actual. If innovate says 13.0 HPT says 12.8. What causes this?
Phil
Old May 1, 2005 | 05:54 PM
HumpinSS's Avatar
Are you using the ground wire on the pigtail
Old May 1, 2005 | 08:00 PM
JNorris's Avatar
Moderator
What is the sampling rate of HPT interface? The LM-1 provides 12 readings per second.
John
Old May 1, 2005 | 08:02 PM
7 Second Club
Yeah its grounded...the reading changes VERY fast. Not sure what to think, the only way to really monitor it is log it.
Old May 1, 2005 | 10:31 PM
jimmyblue's Avatar
Moderator
You have to specify the LM1 output transfer curve
and the HPTuners input transfer curve. Are they
identical? Do they agree at (say) 15.0:1 any
better, or are they offset by the same amount
across the band (that would indicate a ground
offset)?
To maximize the accuracy you might want to set
the LM1 output / HPTuners input to "throw away"
range you're not using - for example, why make
0-5V represent 10.0-20.0:1 AFR if you are well
enough tuned and don't care about anything
outside 11:1 - 16:1? Then the same voltage
range represents with 2X greater accuracy the
AFR.
But do check the LM1 and HPTuners cal curves,
I know the LM1 likes to round down my endpoint
AFR represented and maybe there's a bit slipped
here & there.
Old May 1, 2005 | 10:58 PM
7 Second Club
offset)?
AFR.
here & there.
How fast should the numbers change for the wideband in the HPtuners table display? My numbers cycle soo fast you can't accurately read them.
Phil
Old May 1, 2005 | 11:19 PM
Black02SS's Avatar
Mine cycle fast and I have a Zeitronix.
Old May 2, 2005 | 12:11 AM
Tech's Avatar
FWIW 02 sensor readings change quickly but the PCM uses them for fuel calculations.
