Show me your Shift Tables
Old 09-06-2005, 10:55 AM
Runn's Avatar
Default Show me your Shift Tables
I´d like to know how you have set up your shift Tables...
Old 09-06-2005, 11:23 AM
12secSS's Avatar
Here it is, I have tweaked it a little since then, but essentially the same.
Old 09-06-2005, 12:32 PM
Restricted User
CAT3's Avatar
What size convertor are you running? I had luck with your help, thanks.
Can post mine later when I get home.
Old 09-06-2005, 01:32 PM
12secSS's Avatar
I am running a B&M 3000 stall currently. I tweaked the TCC tables a bit more for low speed cruising/part throttle. I didn't like that it brought down the rpms when cruising under 40. I can post the updated shift tables later. Glad you had good results.
Old 09-06-2005, 03:03 PM
Runn's Avatar
I really like to know how you makes the stock trans feel a little faster and firmer. Give me some tips on how to tune it...
Old 09-06-2005, 03:11 PM
frcefed98's Avatar
Please do, that'll be awesome to try out too.
J
Old 09-06-2005, 04:55 PM
Moderator
jimmyblue's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/230532-auto-tranny-tuning-tables.html
http://home.cfl.rr.com/jimmyblue/PCM_Trans_20041024.xls
Old 09-07-2005, 07:46 AM
Runn's Avatar
Thanks Jimmyblue...
I looked at your excel.file and can i use it on a stock car? and what is your max line pressure set at?
The only thing that changes between different rearend gears are the speed tables right?
Old 09-07-2005, 11:47 AM
AnotherScreenName's Avatar
Originally Posted by D_Run
Thanks Jimmyblue...
Its on the TqMgmt tab - 90 stock.
Old 09-07-2005, 12:42 PM
Runn's Avatar
OK, I see it now... Sorry
Old 09-09-2005, 02:34 PM
Runn's Avatar
I have tried Jimmblue´s table now and it´s a little to hard on low throttle, Guess i have to work a little on it...
Old 09-11-2005, 04:28 PM
Ohio Bird of Prey's Avatar
Since recieving HPTuners this week I too used the setup
provided by Flame Throwing SS and was pleased with the results.
However going into 3rd its bangin the limiter 2 times.
That is killing my et. My 1/8 mile times were great.
I'm throw a MAP "high pressure" code right now and will get it
fixed asap. Maybe then it will upshift perfectly.
Old 09-11-2005, 07:37 PM
Wow, I back the 2-3 mph shift down by 5 mph and its shifting fine.
Now I need to figure out line pressure and etc.
And after checking out Flame Throwing SS web site
all I can say is WOW
