MAFless tuning?
Old Sep 21, 2005 | 10:43 AM
00Z28SS's Avatar
Default MAFless tuning?
I understand the advantages to MAFless tuning; but my question is are people leaving ther MAF sensors disconnected after the tune?
Old Sep 21, 2005 | 10:55 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I did...it runs just fine without it.
Old Sep 21, 2005 | 11:10 AM
00Z28SS's Avatar
To be able to do this, do you have to purchase the 1 bar speed-density option with the HPTuners software?
Old Sep 21, 2005 | 11:15 AM
HumpinSS's Avatar
no you dont HAVE to but it does a few things most importantly
1. gets rid of the secodnary table
2. Re-enables the functionality of the HO and LO tables
Or you could flash your PCM to a 01+ OS and get 1 by default and 2 you will have to copy your HO table to your LO table.
I have been running like this for a year and some change now
Old Sep 21, 2005 | 11:17 AM
MeentSS02's Avatar
Negative...you'll just have to live with running only one octane table (as in, copy the high octane table to the low octane, and leave it that way). You'll still have KR, though, so no worries about that. You just won't give your car any room to "learn" if it gets some bad gas.
Old Sep 21, 2005 | 11:18 AM
MeentSS02's Avatar
Oops...forgot about the 2 different VE tables...damn I'm glad I have an '02.
Old Sep 21, 2005 | 11:23 AM
00Z28SS's Avatar
ok, so I dont need to purchase the 1 bar to be able to run a speed-density system, but if I DO purchase the 1 bar will I still be able to tune with a MAF? I ask because a friend and I are splitting the cost of the software and I want to tune SD, and he wants to tune with a MAF.
Old Sep 21, 2005 | 11:28 AM
HumpinSS's Avatar
1 bar SD package via HPT is licensed per vehicle so you and your buddy can tune anyway you like without one affecting the other
Old Sep 21, 2005 | 11:40 AM
00Z28SS's Avatar
What is involved tuning SD with two VE tables?
Old Sep 21, 2005 | 11:52 AM
HumpinSS's Avatar
the secondary ve table has half the resolution of the primary. The procedures are the same you just lose some resoluion
Old Sep 21, 2005 | 12:04 PM
00Z28SS's Avatar
I have read that the resolution loss is half? Have people been able to produce effective VE tables with that kind of resolution depletion?
Old Sep 21, 2005 | 12:05 PM
SSblack98's Avatar
So if you have a 98 and you tune mafless you will always be running off the "secondary" ve table right? If so, how accurate is this for a daily driver and, ran like this, how does the PCM make fueling changes for drastic temperature changes like winter/summer etc??? Does the IAT sensor still affect fuel delivery? Are the front O2s even used at all? Pardon my ignorance as I am very new to mafless tuning.
Old Sep 21, 2005 | 12:09 PM
MeentSS02's Avatar
I'm sure the PCM can handle it...I think what you are failing to grasp is that there are two types of Speed Density tuning:
1. Open Loop
2. Closed Loop
In closed loop, the PCM uses the stock, narrow band O2 sensors for feedback to adjust the fueling. Your IAT still works, everything still works. You just aren't getting an airflow reading from the MAF sensor. Instead, you are basically telling the PCM just how much air you are getting, and putting it in a format it can understand (the VE table).
The computer just uses a bunch of "look up" tables to determine the airflow...essentially, what you are doing is getting rid of one of those tables.
Old Sep 21, 2005 | 12:42 PM
SSblack98's Avatar
Like I said I am very new to this so I didn't know the PCm can run in closed loop with the MAF unhooked. My tuner has unhooked the MAF and tuned the ve table to about 14.7 afr with a wideband. But this was done at 80 degree ambient temps so will I need to retune when the ambient temps are 30 degrees this winter? I was under the impression that I was now running in open loop all the time witht he maf unplugged. Thanks for the input by the way!
Old Sep 21, 2005 | 12:54 PM
MeentSS02's Avatar
As long as your tuner put you back in closed loop you are running closed loop
You *shouldn't* need a retune for the winter since you still have your IAT sensor...that's all a part of the airflow calculations. I don't know for sure, though, since I've only been running full time SD since early this summer.
Old Sep 21, 2005 | 01:03 PM
MrDude_1's Avatar
no.
as part of the normal calculations, the ambiant tempature of the air is taken into account.
matter of fact, it can go as far as take the measured ambiant air intake temp, and the current engine temp, and correct for the warm engine intake manifold heating the incoming air.
overkill?? in my opinion yes... but its accurate.. lol.
Old Sep 21, 2005 | 01:37 PM
SSblack98's Avatar
Ok, so how do I know if my tuner has me back in closed loop or not? Also, I have pretty bad surging below 2k while driving. I was told I could increase timing at low rpms and help this. What do you all think of that and what would be the best way to go about doing it? Thanks again for all the info...
Old Sep 21, 2005 | 02:19 PM
MrDude_1's Avatar
in my experiance, most of the low speed driving surge can be corrected with VE changes... no timing changes NEEDED....
idle surge however, needs a little of both, and then some..lol
Old Sep 21, 2005 | 03:02 PM
SSblack98's Avatar
My car actually idles very well considering the decent sized cam. TSP did a pretty good job on the original tune with that. It only surges for a little bit when started up cold then smoothes out. But it surges pretty bad while driving at low rpms. It is better or worse at times which I find strange also. Does surging indicate too rich or too lean in the ve table?
Old Sep 21, 2005 | 07:02 PM
speedracer5532's Avatar
Chad, right now you are running in open loop. We need to do some fine tuning on your VE table. We haven't had time since we have been pulling trannies in my car. I can put the car back in closed loop speed density very easy.
