Playing the Devils Advocate Again...
There is also the question of how agressively dyno tuned a package is - since a spot on dyno tune will be to lean/to much advance for the track (unless you have a 2800lb car).
There is also quite a bit more to tuning than just dyno times. To do it correctly you need to drive the car around, monitor part throttle performance, etc. In an automatic, esp. with a large stall, you need to watch shift poitns, TCC clutch lockup, etc.
A good thing to check out would be the methodologies of the tuner in question. If they don't test drive your car, do road tuning, etc. prior to dyno tuning then I would be suspect of the results. You need to verify l-trims are proper, and get the car in a good drivable condition before you focus on WOT numbers.
All imho,
Chris
Once you have them all negative and to go the PE vs RPM how do you know how much fuel to add/subtract? Also, at peak torque I believe I read that you said to richen it up hear. How much is advisable to richen it up by? (Assuming all done on WBO2) <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks.
PS: Vince, I have noticed some of the same things you have regarding dyno's on some cars.
<small>[ June 04, 2002, 11:51 PM: Message edited by: NastyC5 ]</small>
