engine coolant level sensor?
Old Feb 4, 2006 | 03:24 PM
Charlie@LsXperts's Avatar
Default engine coolant level sensor?
my engine coolant level sensor has been lit ever since i got it, just wondering what sets it off because the coolant is full as possible
Old Feb 4, 2006 | 03:45 PM
2001NBMZ28's Avatar
Dirty/bad sensor/connection. You can take it off and try cleaning it, or just unplug it and the light will stay off...or buy a new one.
Old Feb 4, 2006 | 10:37 PM
Potent68's Avatar
Mine's doing the same thing, and if I recall, just unplugging it doesn't work. You'd have to put a jumper between the two terminal's, as the switch is only open when it's working properly, and your radiator is full.
Tom
Old Feb 4, 2006 | 11:00 PM
Blacker's Avatar
Unplugging it will work. I had mine unplugged for about 6 months prior to replacing it.
Old Feb 4, 2006 | 11:06 PM
2001NBMZ28's Avatar
I'm pretty sure you can just unplug it to make the light go off - give it a whirl. Can't check it on mine, don't have one.
Old Feb 4, 2006 | 11:57 PM
bshell's Avatar
My coolant level light came on about 3 months ago. The same day it came on I unplugged the sensor at the back of the radiator. The light has remained off ever since. FWIW, I have no intentions of ever replacing the sensor.
Old Feb 5, 2006 | 03:48 AM
Bombguy99z28's Avatar
It is useful sometimes. I blew a headgasket and wouldn't have realized as quickly without it.
Potent68's Avatar
DOH, now I'll have to go back and play with mine again. :hmm:
Tom
