Why the difference in these 2 Open Loop FA Tables
Old Feb 9, 2006 | 08:49 AM
Billiumss's Avatar
Question Why the difference in these 2 Open Loop FA Tables
I just recently aquired a 2005 Silverado SS LQ9 A4 HPT file to check out. (Might be buying one, but a crew cab, non SS)
I was comparing that file to my file and noticed a few tables that were different.
The Open Loop Fuel Air tables are way different, why? I know one is a 5.7L and the other a 6.0L, but why would they be that much different?
I know other people have brought up before that we should modify this table to reduce the exhaust smell on a cold start especially if we added a cam which will put you in a different/higher/richer MAP range than a stock cam would.
After comparing the 2 files, it seems that the 6.0L truck OLFA should work better for us head and/or cam guys.
What do you guys think?
These 2 are the 5.7L LS1 OLFA Table:
These 2 are the 6.0L LQ9 OLFA Table:
Old Feb 9, 2006 | 09:03 AM
foff667's Avatar
LS1TECH Sponsor
yeah the s-10 file i looked at the other day was similar...might be a truck vs. car thing
Old Feb 9, 2006 | 09:08 AM
Billiumss's Avatar
Open loop is Open loop, especially on a cold start, not moving.
Maybe a HP Tuner or EFI Live guy could chime in and help give an explanation...
Old Feb 9, 2006 | 09:48 AM
soundengineer's Avatar
hey billum...really its just a calibration for all the thing in the vehicle...it should vary between vehicles..especially a modded one
you can calibrate your own with a wieband...
I have a writeup that will be in the HPT help file on the next release, and hopefully I will find some time to put it down in the forums soon as well....
Old Feb 9, 2006 | 09:58 AM
chrisj6's Avatar
different sized engines are going to have different fuel/air tables.
Chris
Old Feb 9, 2006 | 12:36 PM
Billiumss's Avatar
Exclamation
Sent ya PM
Old Feb 9, 2006 | 12:39 PM
Billiumss's Avatar
Chris
Not in this case, the 6.0L and the 5.3L are the same. GM must have a reason to have a different/leaner OLFA.
This is from a 2005 Stock 5.3L A4:
Old Feb 9, 2006 | 12:47 PM
jimmyblue's Avatar
Moderator
I think GM is just retarded, look at the stuff they do
to the PE delay / rate as well. I'm guessing that they
prefer to run low enrichment and low spark to get a
better heavy-load fuel economy, and screw performance.
Old Feb 9, 2006 | 01:50 PM
foff667's Avatar
LS1TECH Sponsor
more evidence gm is retarded is that the 4.3 from an s-10 calibration is more similar to a camaro/firebird LS1 then the 3.8ltr calibration in the camaro/firebird is.
