VE table ???????
Old Mar 7, 2006 | 03:40 PM
NAVY's Avatar
Default VE table ???????
if my corvette 2002 has large cam shift and long headers can i tune VE table, if yes can you pls tech me step by step
thank you
navy
Old Mar 7, 2006 | 04:47 PM
white2001s10's Avatar
Using a MAF? or SD mode?
If MAF mode, then I'm not sure exactly how much effect your VE changes will have. I think the calculation has been posted here before, but I forget it.
I hope you get a good answer here.
Will you be using LS1 Edit? or something else?
Old Mar 7, 2006 | 07:04 PM
LoWeLL216's Avatar
thank you
navy
There are outstanding step-by-step instructions in the stickies on VE Tuning. (Much better than I could type here
Old Mar 7, 2006 | 07:17 PM
joecar's Avatar
navy,
Which software Scan/Tune package are you using...?
Old Mar 8, 2006 | 05:37 AM
NAVY's Avatar
I buy a EFILive FlashScan Scan & Tune Tool, Commercial Edition .
Old Mar 8, 2006 | 05:43 AM
ninobrn99's Avatar
you will need to unplug the maf for one, then log it. you need to see how far off your ve table is. i think efi has a histogram for it. if its over +-10 you will add the difference. once your in the +- range you will just multiply by 1/2 of the error. once you see the histos, it will make more sense. also, since you have a 99 we need to make changes to the primary and secondary ve tables. if you look in the sticky's there is a ls1tuning doc that will walk u through it. its pretty straight foward.
Old Mar 8, 2006 | 10:06 AM
joecar's Avatar
Install the software, and then look at the AutoVE Tuning tutorial in C:\Program Files\EFILive\V7\Doc\Tutorials;
Or see here... http://store.efilive.com/download.aspx#tutorials
this will take you step by step.
Old Mar 8, 2006 | 07:03 PM
NAVY's Avatar
thank you OOOOLLL
