SD tune: Bad for extreme climates?
I'm wanting to get my tune pretty soon, so since it will more than likely be 100* outside when I do it, will I run extremely lean in winter when the air is more dense? In my searches, I've found people saying the opposite, that they run lean in the summer, which doesn't make much sense. Either way, should I stick with the MAF or does weather play less of a role than I'm making it out to be?
Mods are H/C, 4600 stall. 90% street car.
Just make sure you get a tune from someone who knows SD tuning and it will be fine in all climates.
idle spark advance and maybe some throttle cracker
(which on some models is just plain ugly). The MAF is
pretty much ignored at and about idle. A descreened
unit is a negligible restriction, except maybe for the
folks who've gone to 90mm TB and intake with the
cam, heads and exhaust to back it up.
Take a look at (BARO-MAP)/BARO at the top of gear
as a percentage; that's the percentage you stand
to gain, at best, from an infinite sized MAF, TB and
intake orifice as the engine stands today.
(which on some models is just plain ugly)..
Unless there is something physically wrong with the car, I cannot fathom how an experienced tuner cannot tame a small cam like yours, or mine. It almost runs properly on a stock tune... I had my TSP224R 112lsa idling @ 550rpm the other day on a stock tune, just messing around.
Rick
Personally, I have something in the car now which will allow me to adjust the IAT reading which in the end will give my car the correct fueling and limit what the computer makes as a correction. Works quite well.
I personally had a throttle body that was filled and smoothed as such, and I could not get the car to idle properly for the life of me... (nor could several other reputable houston area tuners) I finally broke out the dremel and took out all the epoxy and BOOM, it idled great afterwards.
Also, do you have a hole drilled in the throttle body?
Just some things to look at.
As far as drilling a hole, dont even mess with that. With a small cam like that there should be no issues. Plus you really need to know what you are doing and how to fix the tune before doing that. It can make things even worse.
in general you want your IAC position down around 60ish on a hot idle with fans off,aC off and your hood open to get away from heatsoak when trying to get this done..on ETC vehicles you want TPS to be around 3-4% in these same conditions....
epoxy filled TB only messes with your stuff when you fill too much or dont have a hole atleast the same size as your IAC pintle motor hole is...
I persoanlly dont epoxy them cause the gains you see from it are just wasted money.....
I mean..cmon..is .25 hp really worth all the $$ and work to epoxy a TB??
I've done back t oback dyno pulls with 4 different TB's and saw no gain from one just ported and polished and one epoxy filed...both done by me
it will happen sooner or later, the question is, how soon are you looking for tuning? And your setup shouldn't be impossible for these "heralded" tuners, but then again it all comes down to how much time do you want to spend to get it all accurate as can be. When I was running my TR224, which was years ago, the tuner couldn't get it to idle right. After it warms up it's fine, but it takes a couple minutes to get there. I then went to an F13, had a few tweeks to the tune, but same result. I even brought the car to him another time after he got HP Tuners (had LS1 Edit previously) but no change.
Now I have my current cam and got slight tweaks to the tune by a different tuner. It idles better but still has more surge than it should. For some result he could get it to idle easily with the A/C on, but couldn't with the A/C off. After all of this I'm starting to think something must be wrong with a sensor on the car, and figured if I could eliminate the MAF all together, then maybe it would do the trick. But from what ya'll are saying, it shouldn't make a difference.
BTW, the TB is a Nick Williams, no epoxy or fillers involved. My last TB was a Shaner and the IAC area wasn't filled.
Thanks for the help so far.
