do i need a retune after bigger injectors?
Old 12-11-2006 | 01:26 PM
Houston999's Avatar
Default do i need a retune after bigger injectors?
do i need a retune after bigger injectors? had the stockers and went to SVO 48
Old 12-11-2006 | 01:32 PM
foff667's Avatar
LS1TECH Sponsor
Yes! Definitly.
Old 12-11-2006 | 02:01 PM
SSpdDmon's Avatar
Originally Posted by foff667
Yes! Definitly.
x2...
Old 12-11-2006 | 02:13 PM
98turbls1's Avatar
Originally Posted by SSpdDmon
x2...
x3...I can say this from experience...I put in some 65lb motrons and it ran like junk...
Old 12-12-2006 | 06:54 PM
TAQuickness's Avatar
yes x4. I'd caution you about driving the vehicle with it untuned as well.
Old 12-12-2006 | 07:50 PM
Nakoz's Avatar
x69 just to cover the rest
Old 12-12-2006 | 08:09 PM
koolaid_kid's Avatar
x22 for the backgammon players.....
Old 12-13-2006 | 12:36 PM
Frost's Avatar
Just to be clear, DON'T DRIVE IT WITH THOSE AND NO TUNE. Swap them out when you get to you tuner's shop or trailer yer schizzy over there.
Old 12-13-2006 | 01:00 PM
Ummm, what is a schizzy?
Old 12-13-2006 | 08:03 PM
trod's Avatar
Not to jack the thread but I have a ? Recently had a retune b-cause uped the boost from 6 to 12psi and car is recently running like crap.Well on fast accel. the car has a miss or it feels like its running out of air,fuel or something. Took the car to the shop that tuned and he hooked his laptop up and asked if I had 30pound injectors told him no it has 60's. He tuned my car thinking it had 30. Well he made some changes and said I should be fine. Didnt retune but said if I wanted retune I could make more power? Well my ? is could this hurt my motor if I keep running the car w/out having it retuned?
Old 12-13-2006 | 09:33 PM
gametech's Avatar
If someone "tuned" your motor without even knowing what size injectors it had, RUN AWAY!
Old 12-14-2006 | 07:45 AM
pdanrichey's Avatar
Snap, you should really get that fixed ASAP. The tuning shops typically tune for WOT only, once you get over a certain PSI. So, even with the mishap on the injectors, the car should run well at WOT. The guy that tuned it sounds like a retard. 30# injectors on a boosted car??
IMO, effectively, your PCM is firing the injectors at 30#'s based on the tune, but the injectors don't know how to do that, so they just fire whatever amount they can. I would imagine you're running extremely rich while cruising around (which is why your car is running like crap.) When you go WOT, the tune kicks in and leans the AFR out to a reasonable level.
Remember, it's not how you stand by your car, it's how you race your car...you better learn dat!
Old 12-14-2006 | 09:30 AM
That is SO funny.
But yes, either the tuner should ask or you should tell what changes you have made. Just common sense.
Quick Reply: do i need a retune after bigger injectors?
