Open/closed loop
Old Dec 29, 2006 | 10:47 AM
Vols Fan's Avatar
Default Open/closed loop
I hope this is the right fourm for this question. How can you tell if your car is switching from one to the other? If I'm driving my car down the road the temp hand never moves off 160. If it sets for a few mins it gets up close to 190 or so but as soon as I start moving air around it again it goes right back down. If the car isn't switching am I losing performance? What do I need to do to fix this problem? The car has a stock thermostat.
Old Dec 29, 2006 | 10:51 AM
foff667's Avatar
LS1TECH Sponsor
you should be able to log if your in open or closed loop with a decent scanner. But I will say unless your tuner drastically changed the open loop tables you'll go into closed loop within a few seconds of startup unless your ect temp is very low.
Old Dec 29, 2006 | 11:06 AM
Frost's Avatar
Sounds like the stat may be stuck open.... Are you going by logged temp or the needle on the dash? I read that the temp guages in the 98 actually work and that the 99s and up have them 'dummied' out.
Old Dec 29, 2006 | 11:16 AM
foff667's Avatar
LS1TECH Sponsor
I probably shouldve read past the first couple of lines like frost said it sounds like your tstat mightve seen better days, I would say start by doing a log to view ECT temps to make sure its not the gauge itself, but like frost said the 98's are "fairly" accurate compared to 99+ so I would lean towards the tstat sticking open. Another thing would be to view when your #1 & #2 fans are coming on depending on ECT temp to see if that might be lending a hand in the situation.
Old Dec 29, 2006 | 11:24 AM
Vols Fan's Avatar
By doing a log what does that mean? an how do you do it?
Old Dec 29, 2006 | 11:26 AM
foff667's Avatar
LS1TECH Sponsor
you would need some sort of scanning software...hptuners, efilive, autotap, proscan, etc. something you really should have with a supercharged vehicle
Old Dec 29, 2006 | 11:46 AM
Frost's Avatar
I can't even begin to imagine having an FI setup and not owning a scanning/tuning package; even if it was professionally tuned.
Old Dec 29, 2006 | 12:10 PM
brad8266's Avatar
That engine temp is too cool, the thermostat is likely stuck open.
Old Dec 29, 2006 | 12:35 PM
Vols Fan's Avatar
Ok I'll get it checked out. Thanks
