TPS question.
Old Jun 12, 2007 | 09:36 AM
99blancoSS's Avatar
Default TPS question.
If the TPS isnt working correclty what will the effects be, besides it searching for idle.
Old Jun 12, 2007 | 09:54 AM
LS1curious's Avatar
COnverter Lockup,shift points,Fuelings,Pe modifiers, everything thats using TPs for a factor in implementation.
Old Jun 12, 2007 | 10:26 AM
99blancoSS's Avatar
Would it keep you from reaching full power in an m6 car?
Old Jun 12, 2007 | 11:20 AM
MavrikTA's Avatar
Very good question^^^ EXACTLY what I have been wondering. My cars a 6spd, so it is harder to tell. It idles like crap w/my cam anyway.
Old Jun 12, 2007 | 12:11 PM
slmdLS1's Avatar
im also throwing the p0121 Throttle position code and wondering the same thing. mines running a little on the rich side, but with a base tune.
Old Jun 12, 2007 | 12:17 PM
ICRAZY6's Avatar
A4 here throwing the same code. Help us all!
Old Aug 15, 2007 | 10:54 AM
zheiling's Avatar
same issue bump
Old Aug 15, 2007 | 05:08 PM
Cajun99SS's Avatar
I have it too. It doesnt search for idle but its making my trans shift messed up.
Old Aug 26, 2007 | 11:26 PM
slmdLS1's Avatar
i turned my throttle screw back down(i know i houldnt have touched it to begin with) and my idle dropped just under 1k @ idle. my p0121 code went away. i think that dropped the actual idle just into the range that the pcm sees that it should be.
